Trouble creating a push button toggle switch
I built a circuit meant to move a servo motor, from 0 degrees to 90 degrees by the push of a button.
My goal is that each time i push the button the servo will toggle between 0 and 90.
this is the code i wrote
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
int button = 2;  // The button will be on Pin 7
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
pinMode(pos, OUTPUT);
pinMode(button, INPUT);
digitalWrite (button, LOW);
  if( pos=90){
    if(digitalRead(button)== LOW){
       myservo.write(90); // stay at 90
        delay(50);
  else if(digitalRead(button)== HIGH){
     for(pos=90; pos>0; pos-=5){
        myservo.write(pos); // go to 0
     delay(3000);
  else if(pos=0){
      myservo.write(0); // stay at 0
        delay(50);
     for(pos=0; pos<90; pos+=5){
        myservo.write(pos); // go to 90
     delay(3000);
I added a large delay (I don’t mind the additional time) after each button HIGH to make sure pushing the button is included only in a single loop.
After uploading the following happens:
  • servo starts at 90
  • push button
  • servo goes to 0
  • 3 sec delay
  • servo goes back to 90
I don’t understand why it goes back to 90, since i defined that when the button is LOW and servo is at 0 it should stay at 0.
Any help is appreciated, thanks in Advance
Eran
  if ( pos = 90)
  else if (pos = 0)Fix these attempts at comparison then try the program again
UKHeliBob:
  if ( pos = 90)
How do I fix the comparison attempt, what needs to be changed?
EranT:
assign:
compare:
Got it ! thank you both very much!
