Trouble determining how this code works
I copied this code from a website. It's desined to allow you to turn on and off a LED remotely via the web. The code works fine but I'm at a loss as to how it detects whether you've checked the box and hit submit.
I believe it has something to do with if(readString.indexOf("L=1") >0) but I'm not even sure what that line is doing and where it is getting the data.
Thanks.
#include <SPI.h>
#include <Client.h>
#include <Ethernet.h>
#include <Server.h>
#include <Udp.h>
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = {
  192, 168, 1, 110 };           // ip in lan
byte gateway[] = {
  192, 168, 1, 1 };            // internet access via router
byte subnet[] = {
  255, 255, 255, 0 };                   //subnet mask
Server server(80); //server port
byte sampledata=50; //some sample data - outputs 2 (ascii = 50 DEC)
int ledPin = 4; // LED pin
char link[]="http://www.christophercommunication.org"; //link data
String readString = String(30); //string for fetching data from address
boolean LEDON = false; //LED status flag
void setup(){
  //start Ethernet
  Ethernet.begin(mac, ip, gateway, subnet);
  //Set pin 4 to output
  pinMode(ledPin, OUTPUT);
  //enable serial datada print
void loop(){
  // Create a client connection
  Client client = server.available();
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100)
          //store characters to string
          readString += c; //replaces readString.append(c);
        //output chars to serial port
        Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          //dirty skip of "GET /favicon.ico HTTP/1.1"
          if (readString.indexOf("?") <0)
            //skip everything
            //lets check if LED should be lighted
            if(readString.indexOf("L=1") >0)//replaces if(readString.contains("L=1"))
              //led has to be turned ON
              digitalWrite(ledPin, HIGH); // set the LED on
              LEDON = true;
          else{
            //led has to be turned OFF
            digitalWrite(ledPin, LOW); // set the LED OFF
            LEDON = false;
          // now output HTML data starting with standard header
          client.println("Content-Type: text/html");
          client.println();
          //set background to White
          client.print("<body style=background-color:white>");
          //send first heading
          client.println("<font color='blue'><h1>Web Page based control. </h1><p><h2> over ethernet and Microcontroller</font></p></h2>");
          client.println("<hr />");
          //output some sample data to browser
          client.println("<font color='black' size='5'>Abstract: This Local webpage controls LED (for representational purposes, otherwise, any electronic equipment).");
          client.println("<font color='black' size='4'><p>A microcontroller (Arduino) connected to the internet via the Ethernet shield acts as a middleman to form a communication link between the internet and the microcontroller.</p>");
          client.println("<font color='black' size='4'><p>Check / Uncheck the box for the LED to command lighting on or off respectively</p>");
          client.println("
");//some space between lines
          //printing some link
          client.println("<font color='blue' size='5'>Link: ");
          client.print("<a href=");
          client.print(link);
          client.println(">Visit our site- Chrostopher Communications!</a>");
          client.println("
          //controlling led via checkbox
          client.println("<h1>LED control</h1>");
          //address will look like http://192.168.1.110/?L=1 when submited
          //Creating the checkbox (a type of form in HTML)
          if (LEDON)
            client.println("<form method=get name=LED><input type=checkbox name=L value=1 CHECKED>LED
<input type=submit value=submit></form>");
            client.println("<form method=get name=LED><input type=checkbox name=L value=1>LED
          client.println("
          //printing LED status
          client.print("<font size='5'>LED status: ");
          if (LEDON)
            client.println("<font color='green' size='5'>ON");
            client.println("<font color='grey' size='5'>OFF");
          client.println("</body></html>");
          //clearing string for next read
          readString="";
          //stopping client
          client.stop();
        Serial.print(c);
What is this showing you?
You are accumulating characters read into a string, called readString. The whole string should look something like:
GET / HTTP 1.n
to get the page initially, and like:
GET /?L=1 HTTP 1.n
or:
GET /?L=0 HTTP 1.n
when the submit button is clicked.
If the string contains L=0 or L=1, the code does something.
Ah, I see what you mean. If I check the terminal/console I should be able to determine what is being recieved and then parsed to determine whether the checkbox has been checked or not.
I've been programming for decades but my knowledge of html and network communications is pretty slim.
Thanks for the point in the right direction. I should be able to figure it out from there.
