trouble downloading genuino 101 getting error messages
hello, I just bought a genuino 101 but im getting some error messages.
Error downloading http://downloads.arduino.cc/packages/package_index.json
java.lang.RuntimeException: java.lang.Exception: Error downloading http://downloads.arduino.cc/packages/package_index.json
at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onUpdatePressed$0(ContributionManagerUI.java:151)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.Exception: Error downloading http://downloads.arduino.cc/packages/package_index.json
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:131)
at cc.arduino.contributions.packages.ContributionInstaller.download(ContributionInstaller.java:334)
at cc.arduino.contributions.packages.ContributionInstaller.downloadIndexAndSignature(ContributionInstaller.java:309)
at cc.arduino.contributions.packages.ContributionInstaller.updateIndex(ContributionInstaller.java:287)
at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onUpdatePressed$0(ContributionManagerUI.java:147)
... 1 more
Caused by: java.net.SocketException: Software caused connection abort: recv failed
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.socketRead(SocketInputStream.java:116)
at java.net.SocketInputStream.read(SocketInputStream.java:170)
at java.net.SocketInputStream.read(SocketInputStream.java:141)
at java.io.BufferedInputStream.read1(BufferedInputStream.java:284)
at java.io.BufferedInputStream.read(BufferedInputStream.java:345)
at sun.net.www.MeteredStream.read(MeteredStream.java:134)
at java.io.FilterInputStream.read(FilterInputStream.java:133)
at sun.net.www.protocol.http.HttpURLConnection$HttpInputStream.read(HttpURLConnection.java:3375)
at sun.net.www.protocol.http.HttpURLConnection$HttpInputStream.read(HttpURLConnection.java:3368)
at cc.arduino.utils.network.FileDownloader.downloadFile(FileDownloader.java:209)
at cc.arduino.utils.network.FileDownloader.download(FileDownloader.java:128)
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:129)
... 5 more
I also got another error message but forgot to copy it.
any help would be greatly appreciated.
Thanks
now I'm getting this error message
I'm using a VPN could it be a connection problem?
CRC doesn't match, file is corrupted. It may be a temporary problem, please retry later.
java.lang.RuntimeException: java.lang.Exception: CRC doesn't match, file is corrupted. It may be a temporary problem, please retry later.
at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onInstallPressed$1(ContributionManagerUI.java:176)
Caused by: java.lang.Exception: CRC doesn't match, file is corrupted. It may be a temporary problem, please retry later.
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:91)
at cc.arduino.contributions.packages.ContributionInstaller.install(ContributionInstaller.java:102)
at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onInstallPressed$1(ContributionManagerUI.java:173)
... 1 more
after disconnecting the VPN i'm now getting the erroe message
Sketch uses 886 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xa3
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xa3
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xa3
which makes me think I need to download some drivers
any advice?
I'm really at a loss here i'm now getting this error message.
Error downloading https://github.com/01org/corelibs-arduino101/archive/2.0.2.zip
java.lang.RuntimeException: java.lang.Exception: Error downloading https://github.com/01org/corelibs-arduino101/archive/2.0.2.zip
Caused by: java.lang.Exception: Error downloading https://github.com/01org/corelibs-arduino101/archive/2.0.2.zip
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:69)
... 1 more
Caused by: java.lang.Exception: Incomplete download
at cc.arduino.utils.network.FileDownloader.downloadFile(FileDownloader.java:224)
... 4 more
I think it may be a fake (looks real but not sure I bought it in China)
