Hello!
I'm trying to make a project using ultrasonic sensor and LCD with scrollable menu display. It's still unfinished, but so far there's no error message and I can change the display menu from one to the other without problem.
The problem is when I upload the program to the simulator and my arduino, it won't execute the first 'if' on the case 2. The other 'if's in case 2 works fine tho.
Is there any mistake on my codes?
#include <LiquidCrystal.h>
LiquidCrystal lcd(6, 7, 5, 4, 3, 2);
#define tombolMenu 8 //Tombol menu pada pin D8
#define tombolOk 9 //Tombol ok pada pin D9
#define tombolNaik 10 //Tombol naik pada pin D10
#define tombolTurun 11 //Tombol turun pada pin D11
const int trigPin = 13;
const int echoPin = 12;
long durasi;
int jarak;
int tekanNaik;
int tekanTurun;
int tekanOk;
int jenisKelamin;
int umur = 30;
char menu;
lcd.begin(16,2);
pinMode(tombolMenu, INPUT_PULLUP);
pinMode(tombolOk, INPUT_PULLUP);
pinMode(tombolNaik, INPUT_PULLUP);
pinMode(tombolTurun, INPUT_PULLUP);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
switch (menu){
case 0:
sensorJarak();
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Kalibrasi");
lcd.setCursor(4,1);
lcd.print("cm");
lcd.setCursor(0,1);
lcd.print(jarak);
if(digitalRead(tombolTurun) == LOW){
delay(200);
menu = 1;
if(digitalRead(tombolNaik) == LOW){
delay(200);
menu = 3;
case 1:
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Umur");
lcd.setCursor(0,1);
lcd.print(umur);
lcd.print(" tahun");
delay(200);
menu = 2;
delay(200);
menu = 0;
if(digitalRead(tombolOk) == LOW){
delay(200);
menu = 4;
case 2:
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Jenis Kelamin");
lcd.setCursor(0,1);
lcd.print("Pilih");
delay(200);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Laki");
if(digitalRead(tombolMenu) == LOW){
delay(200);
menu = 2;
delay(200);
menu = 3;
delay(200);
menu = 1;
case 3:
lcd.clear();
sensorJarak();
lcd.setCursor(0,0);
lcd.print("Tinggi lutut");
lcd.setCursor(0,1);
lcd.print(jarak);
lcd.setCursor(4,1);
lcd.print("cm");
delay(200);
menu = 0;
delay(200);
menu = 2;
case 4:
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Umur");
lcd.setCursor(0,1);
lcd.print(umur);
if(digitalRead (tombolNaik) == LOW){
delay(200);
umur = umur + 1;
lcd.setCursor(0,1);
lcd.print(umur);
if(digitalRead (tombolTurun) == LOW){
delay(200);
umur = umur - 1;
lcd.setCursor(0,1);
lcd.print(umur);
if(digitalRead (tombolMenu) == LOW){
delay(200);
menu = 1;
void sensorJarak() {
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
durasi = pulseIn(echoPin, HIGH);
jarak = durasi*0.034/2;
