Trouble getting Serial out
I am trying to interface my Arduino with a Aerocomm ac4790 transceiver (8N1 serial device) by sending a firmware version request, then read the response from the transcevier.
The transmit code works (I debugged it with LED/delay, and there are four 1's in the command and it flashed 4 times), but the read code is not working... Whenever I implement the read code in loop(), the program transmits the request only once (it should loop), so I gather that the read code is getting stuck for some reason.
//March 2, 2009
//Richard Beare
#include <ctype.h>
#define bit9600Delay 84
#define halfBit9600Delay 42
#define bit4800Delay 188
#define halfBit4800Delay 94
byte rx = 6;
byte tx = 7;
byte SWval;
int versionRequest[2];
  pinMode(rx,INPUT);
  pinMode(tx,OUTPUT);
  pinMode(8, OUTPUT);
  digitalWrite(tx,HIGH);
  // Set up command -> version request asks the transceiver for firmware version 0xCC 0x00 0x00
  versionRequest[0] = 204; versionRequest[1] = 0; versionRequest[2] = 0;
void SWprint(int totalBytes, int command[])
  byte mask;
  int currentByte;
  //Iterate through each byte
  for (int i=0; i<totalBytes; i++) {
  currentByte = command[i];
  //startbit
  digitalWrite(tx,LOW);
  delayMicroseconds(bit9600Delay);
  for (mask = 0x01; mask>0; mask <<= 1) {
    if (currentByte & mask){ // choose bit
     digitalWrite(tx,HIGH); // send 1
    else{
     digitalWrite(tx,LOW); // send 0
  //stop bit
  digitalWrite(tx, HIGH);
int SWread()
  byte val = 0;
  while (digitalRead(rx));
  //wait for start bit
  if (digitalRead(rx) == LOW) {
    delayMicroseconds(halfBit9600Delay);
    //response is four bytes
    for (int offset = 0; offset < 32; offset++) {
     val |= digitalRead(rx) << offset;
    //wait for stop bit + extra
    return val;
    SWprint(3, versionRequest);
    int value = SWread(); // Serial.print doesnt seem to work for simple strings/ints either....
As well, Serial.print doesnt seem to work at all...
Any help would be greatly appreciated :slight_smile:
Richard Beare
Hi Richard, is there a reason you are not using the SoftwareSerial library distributed with Arduino?
But even better is the very nice library here: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1233298805
