Trouble in getting RFID tag value from serial port of computer
I am developing a RFID attendance counting system for my classroom. I have interfaced MFRC-522 RFID module with Arduino Uno. The Arduino Uno is connected to a PC via serial port. A C# program reads the serial port to get the RFID tag number and performs matching.
Now, the C# program can successfully read the whole 13-digit number of the card only when it is the first scan. But in the next scans for the same card, the 13-digit number breaks into several parts. The console output of two consecutive tests are shown below:
Press any key to continue...
Data Received: 160975869190 Matched
Data Received: 1 Not Matched
Data Received: 6097 Not Matched
Data Received: 5869 Not Matched
Data Received: 190 Not Matched
I can not figure out why the card number can be read at the first scan but the number breaks into several parts in the next scans? The both Arduino and C# codes are included below:
Arduino Code:
  SPI.begin();
  rfid.init();
   if(rfid.isCard())
    RoutineRFID();
void RoutineRFID()
  if(rfid.readCardSerial())
     Serial.print(rfid.serNum[0]);
     Serial.print(rfid.serNum[1]);
     Serial.print(rfid.serNum[2]);
     Serial.print(rfid.serNum[3]);
     Serial.print(rfid.serNum[4]);
     Serial.flush();
  while(!Serial.available())
  String studentName = Serial.readString();
  lcd.print(studentName);
  delay(3000);
C# Code:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.IO.Ports;
namespace Test_Serial
    class Program
        static void Main(string[] args)
            try{
            SerialPort myPort = new SerialPort();
            myPort.BaudRate = 9600;
            myPort.PortName = "COM6";
            myPort.Open();
            myPort.DataReceived += new SerialDataReceivedEventHandler(DataReceivedHandler);
            Console.WriteLine("Press any key to continue...");
            Console.WriteLine();
            Console.ReadKey();
            myPort.Close();
            catch (Exception ex)
                Console.WriteLine("Com port Disconnected!");
        private static void DataReceivedHandler(
                        object sender,
                        SerialDataReceivedEventArgs e)
            SerialPort sp = (SerialPort)sender;
            string indata = sp.ReadExisting();
            Console.WriteLine("Data Received:");
            Console.WriteLine(indata);
            if (String.Equals(indata, "160975869190"))
                Console.WriteLine("Matched");
                sp.WriteLine("Matched");
                Console.WriteLine("Not Matched");
                sp.WriteLine("Not Matched");
     Serial.flush();
How is the C# program supposed to know when a packet ends? Yousendonepacketafteranotherwithnothingshowingwhereapacketstartsorends.
Read whatever has arrived, whether that is one packet, a part of a packet, or 12 packets. Hmmm.
Thank you very much. I have fixed it :slight_smile:
