Trouble in tca9548a at sketch serial
Hello There…
First, please watch my code…
#include <Wire.h>
extern "C" {
#include "utility/twi.h"  // from Wire library, so we can do bus scanning
#define TCAADDR 0x70
#define hellee 0x71
void tcaselect(uint8_t i) {
  if (i > 7) return;
  Wire.beginTransmission(TCAADDR);
  Wire.write(1 << i);
  Wire.endTransmission();
void helle(uint8_t i) {
  if (i > 7) return;
  Wire.beginTransmission(hellee);
  Wire.write(1 << i);
#include <Wire.h>
#include <MechaQMC5883.h>
MechaQMC5883 qmc0;
MechaQMC5883 qmc1;
MechaQMC5883 qmc2;
MechaQMC5883 qmc3;
MechaQMC5883 qmc4;
  Wire.begin();
  qmc0.init();
   qmc1.init();
  qmc2.init();
  qmc3.init();
  qmc4.init();
  pinMode(13, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(11, OUTPUT);
//Serial.println("CLEARSHEET");
 // Serial.println("CLEARDATA");
//Serial.println("x,y,z,azimuth");
  //qmc.setMode(Mode_Continuous,ODR_200Hz,RNG_2G,OSR_256);
   int x0, y0, z0;
   int x2, y2, z2;
   int x3, y3, z3;
    int x4, y4, z4;
   int x5, y5, z5;
   int x6, y6, z6;
    int x7, y7, z7;
   int x1, y1, z1;
digitalWrite(13, HIGH);
digitalWrite(12, LOW);
digitalWrite(11, LOW);
  tcaselect(4);
//Serial.println("CLEARDATA");
//Serial.println("LABEL,TIME,TEMP,HUMI")
  //float azimuth; //is supporting float too
  qmc0.read(&x0, &y0, &z0);
  Serial.print(x0);
  Serial.println(" a0");
//  Serial.print(y0);
 // Serial.println(" b0");
  Serial.print(z0);
  Serial.println(" c0");
  tcaselect(5);
  qmc1.read(&x1, &y1, &z1);
  Serial.print(x1);
  Serial.println(" a1");
  Serial.print(z1);
  Serial.println(" c1");
   tcaselect(6);
  qmc2.read(&x2, &y2, &z2);
  Serial.print(x2);
  Serial.println(" a2");
  Serial.print(z2);
  Serial.println(" c2");
 tcaselect(7);
  qmc3.read(&x3, &y3, &z3);
  Serial.print(x3);
  Serial.println(" a3");
  Serial.print(z3);
  Serial.println(" c3");
  helle(2);
qmc4.read(&x4, &y4, &z4);
  Serial.print(x4);
  Serial.println(" a4");
  Serial.print(z4);
  Serial.println(" c4");
I have 2 trouble about this code…
First,When I run this code, only tcaselect(7) show a result and others are all 0. So I change tcaselect(7)
to tcaselect(4) and then run, the tcaselect(4) change tcaselect(5) until 7 and then Finally I get full of the data… How horrible… When I reboot my computers power, (That mean next day or something…)
I Do the same thing for about 7 minute. I just want the data at first running So Could you solve my problem?
And second, I mention ‘helle’ is second tca9548 chip but when I run the code, tcaselect(7) and helle(2) value was same. Maybe it would be combined… So When I eliminate helle then tcaselect(7) value going to normal… What sould I do :frowning:
It might help to show us a wiring diagram of your setup. Without it we have no chance to know what that sketch should do.
And explain why the sketch includes code for 5 3-axis magnetometers. The sketches you post should be the minimal sketch to reproduce the error. So are the 5 magnetometers necessary?
