Hello,
I’m having a problem interpreting the output from an air flow sensor.
I’m using an Arduino Mega 2560, Arduino 1.0.4 and Windows XP. The sensor is a Sensirion EM1 air flow sensor, part #EM1NV4R0V_1A.
The spec sheet is here: http://www.sensirion.com/fileadmin/user_upload/customers/sensirion/Dokumente/GasFlow/Sensirion_Gas_Flow_EM1_Datasheet_V3.pdf
It’s also an attachment below.
Per the spec sheet (Page 7) The measurement values are provided as a 16 bit signed integer in binary format with 2 bytes synchronization preceding.
sync 0x7F
sync 0x7F
MSB
LSB
In addition, The received value is a 16 bit signed integer in the two’s complement representation. The calibrated data is multiplied by a constant factor and then rounded to the next smaller integer in order to transfer also fractions of a unit through the integer protocol.
The air flow value should be 60.00 and I get 53.99
Here’s my code:
int incomingByte1 = 0; //1st sync byte
int incomingByte2 = 0; // 2nd sync byte
int msb = 0; //most significant byte of data
int lsb = 0; // least significant byte of data
int measurementBit = 0; // declare variable to hold 16 bit signed integer in binary format
int FlowScaleFactorDivision = 128; // declare variable for the flow scale factor of 1/128 ln/min
float ActualMeasurement = 0.0;
if (Serial2.available()>=4) {
incomingByte1 = Serial2.read();
incomingByte2 = Serial2.read();
msb = Serial2.read();
lsb = Serial2.read();
if (incomingByte1 == syncbyte && incomingByte2 == syncbyte && msb != syncbyte); {
measurementBit = msb + (lsb<<8);
ActualMeasurement = measurementBit / FlowScaleFactorDivision;
Serial.println(ActualMeasurement);
Any thoughts?
Regards,
Mark
