trouble loading program -Loading configuration fails
Hello, I have uninstalled and reinstalled my Arduino software, because of an issue I had with a AVR file.
After install when I click on the Arduino icon, the start up screen will start and at the bottom it read,
"LOADING CONFIGURATION". then the screen goes away and nothing.
any IDEAs?
I figured it out, I installed the program as Administrator
so I must right click the Arduino Icon and run as administrator the it loaded.. (weird!!)
but it loads now..
You really shouldn't have to do that - 1.6.x should work correctly without admin privs.
What version of the IDE are you using, and what version were you using? Did you previously have a 1.5.x installed? 1.5.x leaves behind files that interfere with 1.6.x
