I am using the arduino uno with the display shield. I created a menu system that you can go through and pick different options like seeing the time or atmospheric pressure. I am having trouble on getting the real time clock to loop without being in void loop though. I want to be able to go into the clock section in the menu and have it count up each second. But when i put the code for the clock in the void loop it puts it over top of everything. So I need to like reference it in void loop without the code being actually in void loop i think. I have no idea how to do it and any help would be great.
#include <Wire.h>
#include <RTClib.h> //Clock
#include <LiquidCrystal.h>
RTC_DS1307 rtc;
// Initialize the library with the numbers of the interface pins
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
//States for the menu.
int currentMenuItem = 0;
int lastState = 0;
Wire.begin();
rtc.begin();
//Set the characters and column numbers.
lcd.begin(16, 2);
//Print default title.
clearPrintTitle();
if (! rtc.isrunning())
rtc.adjust(DateTime((__DATE__),(__TIME__)));
//Call the main menu.
mainMenu();
void mainMenu() {
//State = 0 every loop cycle.
int state = 0;
//Refresh the button pressed.
int x = analogRead (0);
//Set the Row 0, Col 0 position.
lcd.setCursor(0,0);
//Check analog values from LCD Keypad Shield
if (x < 100) {
//Right
} else if (x < 200) {
//Up
state = 1;
} else if (x < 400){
//Down
state = 2;
} else if (x < 600){
//Left
} else if (x < 800){
//Select
state = 3;
//If we are out of bounds on th menu then reset it.
if (currentMenuItem < 0 || currentMenuItem > 4) {
//If we have changed Index, saves re-draws.
if (state != lastState) {
if (state == 1) {
//If Up
currentMenuItem = currentMenuItem - 1;
displayMenu(currentMenuItem);
} else if (state == 2) {
//If Down
currentMenuItem = currentMenuItem + 1;
} else if (state == 3) {
//If Selected
selectMenu(currentMenuItem);
//Save the last State to compare.
lastState = state;
//Small delay
delay(5);
//Display Menu Option based on Index.
void displayMenu(int x) {
switch (x) {
case 1:
clearPrintTitle();
lcd.print ("-> Date and Time");
case 2:
clearPrintTitle();
lcd.print ("-> Atmo.Pressure");
case 3:
clearPrintTitle();
lcd.print ("-> Light Intens.");
case 4:
clearPrintTitle();
lcd.print ("-> Menu Option 4");
//Print a basic header on Row 1.
void clearPrintTitle() {
lcd.clear();
lcd.setCursor(0,0);
lcd.print(" Hello! ");
lcd.setCursor(0,1);
//Show the selection on Screen.
void selectMenu(int x) {
switch (x) {
case 1:
{DateTime now = rtc.now();
lcd.setCursor(0,0);
lcd.print(now.month(), DEC);
lcd.print('/');
lcd.print(now.day(), DEC);
lcd.print('/');
lcd.print(now.year(), DEC);
lcd.setCursor(0,1);
lcd.print((now.hour() < 10 ? "0" : "") + String(now.hour()) + ":" +
(now.minute() < 10 ? "0" : "") + now.minute() + ":" +
(now.second() < 10 ? "0" : "") + now.second());
//Call the function that belongs to Option 1
case 2:
clearPrintTitle();
lcd.print ("Selected Opt 2");
//Call the function that belongs to Option 2
case 3:
clearPrintTitle();
lcd.print ("Selected Opt 3");
//Call the function that belongs to Option 3
case 4:
clearPrintTitle();
lcd.print ("Selected Opt 4");
//Call the function that belongs to Option 4
display.ino (3.44 KB)
