I'm trying to get GPS and pressure readings from my Arduino Uno. However, when I try to get pressure/temperature readings off of the pressure sensor (code snippet below), the GPS starts sending malformed packets to my serial monitor. I'd like to be able to get good GPS and pressure readings from my Arduino. (Hardware details provided below)
float temperature_c, temperature_f;
double pressure_abs, pressure_relative, altitude_delta, pressure_baseline;
String dataString = "";
pressure_abs = sensor.getPressure(ADC_4096); //IF THIS LINE REMOVED, GPS SENDS GOOD DATA.
Here's the full code:
#include <SoftwareSerial.h>
//pressure sensor libraries
#include <Wire.h>
#include <SparkFun_MS5803_I2C.h>
//datalogger library
#include <SPI.h>
#include <SD.h>
// set up datalogger
const int chipSelect = 4;
/*-----------GPS-----------*/
SoftwareSerial gpsSerial(10, 11); // RX, TX (TX not used)
const int sentenceSize = 80;
char sentence[sentenceSize];
/*------------Pressure sensor-------*/
// Begin class with selected address
// available addresses (selected by jumper on board)
// default is ADDRESS_HIGH
// ADDRESS_HIGH = 0x76
// ADDRESS_LOW = 0x77
MS5803 sensor(ADDRESS_HIGH);
// Create Variable to store altitude in (m) for calculations;
double pressure_baseline;
double base_altitude = 1655.0; // Altitude of SparkFun's HQ in Boulder, CO. in (m)
gpsSerial.begin(9600);
/*----------Pressure sensor stuff----------*/
Serial.println("\ntemperature (C), temperature (F), pressure (abs), pressure (relative), change in altitude");
//Retrieve calibration constants for conversion math.
sensor.reset();
sensor.begin();
pressure_baseline = sensor.getPressure(ADC_4096);
Serial.println(pressure_baseline);
Serial.println("\n");
static int i = 0;
if (gpsSerial.available())
// Serial.print("GPS Serial is available\n");
char ch = gpsSerial.read();
if (ch != '\n' && i < sentenceSize)
sentence[i] = ch;
i++;
sentence[i] = '\0';
i = 0;
// Serial.println("\n");
Serial.println(sentence);
displayGPS();
/*----------------------PRESSURE SENSOR-------------------------*/
/*--------------------------Pressure sensor methods----------------*/
// Thanks to Mike Grusin for letting me borrow the functions below from
// the BMP180 example code.
double sealevel(double P, double A)
// Given a pressure P (mbar) taken at a specific altitude (meters),
// return the equivalent pressure (mbar) at sea level.
// This produces pressure readings that can be used for weather measurements.
return(P/pow(1-(A/44330.0),5.255));
double altitude(double P, double P0)
// Given a pressure measurement P (mbar) and the pressure at a baseline P0 (mbar),
// return altitude (meters) above baseline.
return(44330.0*(1-pow(P/P0,1/5.255)));
void displayGPS()
char field[20];
getField(field, 0);
if (strcmp(field, "$GPGGA") == 0)
Serial.print("Lat: ");
getField(field, 2); // number
Serial.print(field);
getField(field, 3); // N/S
Serial.print(" Long: ");
getField(field, 4); // number
getField(field, 5); // E/W
Serial.println(field);
Serial.print("Altitude: ");
getField(field, 9);
Serial.print("Number of satellites: ");
getField(field, 7);
Serial.println("-----------------------\n");
void getField(char* buffer, int index)
int sentencePos = 0;
int fieldPos = 0;
int commaCount = 0;
while (sentencePos < sentenceSize)
if (sentence[sentencePos] == ',')
commaCount ++;
sentencePos ++;
if (commaCount == index)
buffer[fieldPos] = sentence[sentencePos];
fieldPos ++;
sentencePos ++;
buffer[fieldPos] = '\0';
When the line to get pressure is commented like so...
// pressure_abs = sensor.getPressure(ADC_4096); //IF THIS LINE REMOVED, GPS SENDS GOOD DATA.
...my GPS gives me proper packets of data:
$GPGSA,A,1,,,,,,,,,,,,,0.0,0.0,0.0*30
$GPRMC,120208.000,V,24006,,,N*71
$GPVTG,000.0,T,,M,000.0,N,000.0,K,N*02
$GPGGA,120209.000,2400.0000,N,12100.0000,E,0,00,0.0,0.0,M,0.0,M,,0000*61
Lat: 2400.0000N Long: 12100.0000E
Altitude: 0.0
Number of satellites: 00
$GPRMC,120209.000,V,24006,,,N*70
$GPGGA,120210.000,2400.0000,N,12100.0000,E,0,00,0.0,0.0,M,0.0,M,,0000*69
Altitude: 0.0
$GPRMC,120210.000,V,240006,,,N*78
$GPGGA,120211.000,2400.0000,N,12100.0000,E,0,00,0.0,0.0,M,0.0,M,,0000*68
Altitude: 0.0
But when my line to get pressure is uncommented...
My GPS packets become malformed:
$GPGGA,120125.000,2400.0000,N,12100.0000,E,0,00,0.0,0.0,M,0.0,M,,$0,0T,$GPGGA,12
Altitude: 0.0
126.000,2400.0000,N,120,00..
$GPGGA,120127.000,2400.0000,N,100,$GPGGA,120128.000,2400.0000,N,1200,20*0$GPGGA,
Lat: 2400.0000N Long: 100$GPGGA
Altitude: 1200
Number of satellites: 2400.0000
20129.000,2400.0000,N,120G.4,,*$GPGGA,120130.000,2400.0000,N,1060$GPGGA,120131.0
0,2400.0000,N,12,*..E
0$GPGGA,120132.000,2400.0000,N,120A00.0
$GPGGA,120133.000,2400.0000,N,1M,
0,,$GPGGA,120134.000,2400.0000,N,1200,1070$GPGGA,120135.000,2400.0000,N,10,,,0,0
GPGGA,120136.000,2400.0000,N,120G0,0V,$GPGGA,120137.000,2400.0000,N,1,,30000
$GP
GA,120138.000,2400.0000,N,0G00V0VK$GPGGA,120139.000,2400.0000,N1,,VP,6,$GPGGA,12
140.000,2400.0000,N,1.,0*.0.
$GPGGA,120141.000,2400.0000,N,0A*00*N$GPGGA,120142.000,2400.0000,N,.,,110,0$GPGG
Lat: 2400.0000N Long: 0A*00*N$GPGGA120142.000
Altitude: ,110
Number of satellites: N
,120143.000,2400.0000,N,1,,P$02,$GPGGA,120144.000,2400.0000,N,10.0$GPGGA,120145.
00,2400.0000,N,10A*00000$GPGGA,120146.000,2400.0000,N,0G.020,*$GPGGA,120147.000,
400.0000,N0,,20,0$GPGGA,120148.000,2400.0000,N,120P,,0P,$GPGGA,120149.000,2400.0
00,N,1.S0000*$GPGGA,120150.000,2400.0000,N,1.,,,0,0$GPGGA,120151.000,2400.0000,N
100,50E,$GPGGA,120152.000,2400.0000,N,120S.00,N$GPGGA,120153.000,2400.0000,N,1.A
0002$GPGGA,120154.000,2400.0000,N,1.,,00N,$GPGGA,120155.000,2400.0000,N,1E*..0A0
GPGGA,120156.000,2400.0000,N,120S0400N$GPGGA,120157.000,2400.0000,N,1.A0.000$GPG
A,120158.000,2400.0000,N,100,2.N.$GPGGA,120159.000,2400.0000,N,100,906,$GPGGA,12
200.000,2400.0000,N,120,*000*$GPGGA,120201.000,2400.0000,N,10,,,.GN$GPGGA,120202
000,2400.0000,N,11,,C160$GPGGA,120203.000,2400.0000,N,12,6.00
,$GPGGA,120204.000
2400.0000,N,100,00*,$GPGGA,120205.000,2400.0000,N,120,300.
$GPGGA,120206.000,2400.0000,N,1.,R,0M$GPGGA,120207.000,2400.0000,N,12,00007N$GPG
Lat: 2400.0000N Long: 1.R
Altitude: N
Number of satellites: 120207.000
Hardware:
Arduino board: Arduino Uno R3
GPS: Venus GPS (made by Sparkfun)
Pressure sensor: Ms5803-14BA Breakout (made by Sparkfun)
Data logger: OpenLog (made by Sparkfun)
Here's my setup:
What's causing my GPS to send bad packets? Evidently, the pressure sensor is somehow interfering with the GPS, but how is it doing that and how can I avoid interference?
