Trouble reading from 5mp ArduCAM
Hi all,
I'm trying to create an AI person detection kit using Arduino Nano BLE Sense, TensorFlow and an ArduCAM 5mp camera for my final university project.
I've been following instructions from here:
https://create.arduino.cc/projecthub/little_lookout/person-detection-with-tensorflow-and-arduino-47ae01
and here:
https://github.com/tensorflow/tensorflow/blob/master/tensorflow/lite/micro/examples/person_detection/README.md#running-on-arduino
but instead of using the 2mp OV2640 I've had to use the 5MP OV5642.
I've edited the ArduCAM library to work for OV5642 and the camera code but when I upload the code the Arduino isn't reading from the camera.
I've put a copy of the code at the end of this post.
If anyone is able to help me get it reading from the 5mp OV5642 that would be great.
Thanks!
// Required by Arducam library
#include <SPI.h>
#include <Wire.h>
#include <memorysaver.h>
// Arducam library
#include <ArduCAM.h>
// JPEGDecoder library
#include <JPEGDecoder.h>
// Checks that the Arducam library has been correctly configured
#if !(defined OV5642_MINI_5MP_PLUS)
#error Please select the hardware platform and camera module in the Arduino/libraries/ArduCAM/memorysaver.h
#endif
// The size of our temporary buffer for holding
// JPEG data received from the Arducam module
#define MAX_JPEG_BYTES 4096
// The pin connected to the Arducam Chip Select
#define CS 7
// Camera library instance
ArduCAM myCAM(OV5642, CS);
// Temporary buffer for holding JPEG data from camera
uint8_t jpeg_buffer[MAX_JPEG_BYTES] = {0};
// Length of the JPEG data currently in the buffer
uint32_t jpeg_length = 0;
// Get the camera module ready
TfLiteStatus InitCamera(tflite::ErrorReporter* error_reporter) {
error_reporter->Report("Attempting to start Arducam");
// Enable the Wire library
Wire.begin();
// Configure the CS pin
pinMode(CS, OUTPUT);
digitalWrite(CS, HIGH);
// initialize SPI
SPI.begin();
// Reset the CPLD
myCAM.write_reg(0x07, 0x80);
delay(100);
myCAM.write_reg(0x07, 0x00);
delay(100);
// Test whether we can communicate with Arducam via SPI
myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
uint8_t test;
test = myCAM.read_reg(ARDUCHIP_TEST1);
if (test != 0x55) {
error_reporter->Report("Can't communicate with Arducam");
return kTfLiteError;
// Use JPEG capture mode, since it allows us to specify
// a resolution smaller than the full sensor frame
myCAM.set_format(JPEG);
myCAM.InitCAM();
// Specify the smallest possible resolution
myCAM.OV5642_set_JPEG_size(OV5642_320x240);
delay(100);
return kTfLiteOk;
// Begin the capture and wait for it to finish
TfLiteStatus PerformCapture(tflite::ErrorReporter* error_reporter) {
error_reporter->Report("Starting capture");
// Make sure the buffer is emptied before each capture
myCAM.flush_fifo();
myCAM.clear_fifo_flag();
// Start capture
myCAM.start_capture();
// Wait for indication that it is done
while (!myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK)) {
error_reporter->Report("Image captured");
delay(50);
// Clear the capture done flag
return kTfLiteOk;
// Read data from the camera module into a local buffer
TfLiteStatus ReadData(tflite::ErrorReporter* error_reporter) {
// This represents the total length of the JPEG data
jpeg_length = myCAM.read_fifo_length();
error_reporter->Report("Reading %d bytes from Arducam", jpeg_length);
// Ensure there's not too much data for our buffer
if (jpeg_length > MAX_JPEG_BYTES) {
error_reporter->Report("Too many bytes in FIFO buffer (%d)",
MAX_JPEG_BYTES);
if (jpeg_length == 0) {
error_reporter->Report("No data in Arducam FIFO buffer");
myCAM.CS_LOW();
myCAM.set_fifo_burst();
for (int index = 0; index < jpeg_length; index++) {
jpeg_buffer[index] = SPI.transfer(0x00);
delayMicroseconds(15);
error_reporter->Report("Finished reading");
myCAM.CS_HIGH();
return kTfLiteOk;
// Decode the JPEG image, crop it, and convert it to greyscale
TfLiteStatus DecodeAndProcessImage(tflite::ErrorReporter* error_reporter,
int image_width, int image_height,
uint8_t* image_data) {
error_reporter->Report("Decoding JPEG and converting to greyscale");
// Parse the JPEG headers. The image will be decoded as a sequence of Minimum
// Coded Units (MCUs), which are 16x8 blocks of pixels.
JpegDec.decodeArray(jpeg_buffer, jpeg_length);
// Crop the image by keeping a certain number of MCUs in each dimension
const int keep_x_mcus = image_width / JpegDec.MCUWidth;
const int keep_y_mcus = image_height / JpegDec.MCUHeight;
// Calculate how many MCUs we will throw away on the x axis
const int skip_x_mcus = JpegDec.MCUSPerRow - keep_x_mcus;
// Roughly center the crop by skipping half the throwaway MCUs at the
// beginning of each row
const int skip_start_x_mcus = skip_x_mcus / 2;
// Index where we will start throwing away MCUs after the data
const int skip_end_x_mcu_index = skip_start_x_mcus + keep_x_mcus;
// Same approach for the columns
const int skip_y_mcus = JpegDec.MCUSPerCol - keep_y_mcus;
const int skip_start_y_mcus = skip_y_mcus / 2;
const int skip_end_y_mcu_index = skip_start_y_mcus + keep_y_mcus;
// Pointer to the current pixel
uint16_t* pImg;
// Color of the current pixel
uint16_t color;
// Loop over the MCUs
while (JpegDec.read()) {
// Skip over the initial set of rows
if (JpegDec.MCUy < skip_start_y_mcus) {
continue;
// Skip if we're on a column that we don't want
if (JpegDec.MCUx < skip_start_x_mcus ||
JpegDec.MCUx >= skip_end_x_mcu_index) {
continue;
// Skip if we've got all the rows we want
if (JpegDec.MCUy >= skip_end_y_mcu_index) {
continue;
pImg = JpegDec.pImage;
// The x and y indexes of the current MCU, ignoring the MCUs we skip
int relative_mcu_x = JpegDec.MCUx - skip_start_x_mcus;
int relative_mcu_y = JpegDec.MCUy - skip_start_y_mcus;
// The coordinates of the top left of this MCU when applied to the output
// image
int x_origin = relative_mcu_x * JpegDec.MCUWidth;
int y_origin = relative_mcu_y * JpegDec.MCUHeight;
// Loop through the MCU's rows and columns
for (int mcu_row = 0; mcu_row < JpegDec.MCUHeight; mcu_row++) {
// The y coordinate of this pixel in the output index
int current_y = y_origin + mcu_row;
for (int mcu_col = 0; mcu_col < JpegDec.MCUWidth; mcu_col++) {
// Read the color of the pixel as 16-bit integer
color = *pImg++;
// Extract the color values (5 red bits, 6 green, 5 blue)
uint8_t r, g, b;
r = ((color & 0xF800) >> 11) * 8;
g = ((color & 0x07E0) >> 5) * 4;
b = ((color & 0x001F) >> 0) * 8;
// Convert to grayscale by calculating luminance
// See Grayscale - Wikipedia for magic numbers
float gray_value = (0.2126 * r) + (0.7152 * g) + (0.0722 * b);
// The x coordinate of this pixel in the output image
int current_x = x_origin + mcu_col;
// The index of this pixel in our flat output buffer
int index = (current_y * image_width) + current_x;
image_data[index] = static_cast<uint8_t>(gray_value);
error_reporter->Report("Image decoded and processed");
return kTfLiteOk;
// Get an image from the camera module
TfLiteStatus GetImage(tflite::ErrorReporter* error_reporter, int image_width,
int image_height, int channels, uint8_t* image_data) {
static bool g_is_camera_initialized = false;
if (!g_is_camera_initialized) {
TfLiteStatus init_status = InitCamera(error_reporter);
if (init_status != kTfLiteOk) {
error_reporter->Report("InitCamera failed");
return init_status;
g_is_camera_initialized = true;
TfLiteStatus capture_status = PerformCapture(error_reporter);
if (capture_status != kTfLiteOk) {
error_reporter->Report("PerformCapture failed");
return capture_status;
TfLiteStatus read_data_status = ReadData(error_reporter);
if (read_data_status != kTfLiteOk) {
error_reporter->Report("ReadData failed");
return read_data_status;
TfLiteStatus decode_status = DecodeAndProcessImage(
error_reporter, image_width, image_height, image_data);
if (decode_status != kTfLiteOk) {
error_reporter->Report("DecodeAndProcessImage failed");
return decode_status;
return kTfLiteOk;
Welcome to the Forum. Please read these two posts:
General Guidance and How to use the Forum
and
Read this before posting a programming question ...
You may also find useful information that would answer your question here:
Useful links - check here for reference posts / tutorials
It is important to provide as much of the information that is needed to solve your problem as you can, in your first posts. The forum link above has guidelines for posting in a standard way that makes it easiest for people to provide you with useful answers. Making an effort to do this will greatly increase the number and quality of helpful responses that you get.
In this case, the problem is that you have posted code without using code tags. The code tags make the code look
like this
when posting source code files. It makes it easier to read, and can be copied with a single mouse click. Also, if you don't do it, some of the character sequences in the code can be misinterpred by the forum code as italics or funny emoticons. The "Code: [Select]" feature allows someone to select the entire sketch so it can be easily copied and pasted into the IDE for testing or review.
If you have already posted without using code tags, open your message and select "modify" from the pull down menu labelled, "More", at the lower right corner of the message. Highlight your code by selecting it (it turns blue), and then click on the "</>" icon at the upper left hand corner. Click on the "Save" button. Code tags can also be inserted manually in the forum text using the code and /code metatags.
