Trouble reading LSM6DS3 Accelerometer Data via Pro Mini
I’m having trouble reading accelerometer data from a LSM6DS3 IMU.
The LSM6DS3 is connected to a Pro Mini 328P (5V, 16MHz) via an FTDI USB board.
I have been using this equipment successfully for a few years now. The problem now is that additional backup units are not reading the accelerometer data correctly: when I upload my sketch, all axis read “13.25” in the serial monitor of the Arduino application on my MacBook Pro.
Hypotheses I have ruled out:
  1. Board, Processor and Port settings in the Arduion application. Code uploads successfully. I’m afraid to try uploading to the working board because I need to have at least one working unit.
  2. All hardware. I have successfully tested each component with the one working Pro Mini. The non-working Pro Minis do send correct digital data, so I know that all Pro Minis and all LSM6DS3s are not broken.
  3. Serial speed. The digital pins do read correctly on all Pro Minis.
  4. Hardware/software incompatibility due to changes in the header files. Header file has a date of 2015, which was about the time I bought the hardware.
Here is the code I’m using:
#include "SparkFunLSM6DS3.h"
#include "Wire.h"
#include "SPI.h"
LSM6DS3 myIMU; //Default constructor is I2C, addr 0x6B
int x = 0;
  delay(1000); //relax...
  Serial.println("Processor came out of reset.\n");
  for (int pin=2; pin<7; pin++) { pinMode(pin,INPUT_PULLUP); }
  //Call .begin() to configure the IMU
  myIMU.begin();
for (int pin= 2; pin<=6; pin++){     // Read and send digital pins 2-6
    x = digitalRead(pin);
    sendInt ( (x - 1) * -1 );
//Get IMU parameters (accelerometer & gyroscope)
//accelerometer
    sendFloat(myIMU.readFloatAccelX());
    sendFloat(myIMU.readFloatAccelY());
    sendFloat(myIMU.readFloatAccelZ());
//gyroscope
//  sendFloat(myIMU.readFloatGyroX());
//  sendFloat(myIMU.readFloatGyroY());
//  sendFloat(myIMU.readFloatGyroZ());
  delay(10);
void sendInt (int x){              // function to send the pin value followed by a "space".
 Serial.print(x);
 Serial.print( " " );
void sendFloat (float x){              // function to send the pin value followed by a "space".
 Serial.print(x);
I’m completely baffled at this point. Can someone offer any additional suggestions? Thanks so much.
Anybody have any ideas? If not, could somebody suggest alternative places where I might post this? Thanks so much.
