Trouble Reading three analog inputs on serial monitor
I am working on a project where I need to read three different analog inputs; one for each potentiometer.
When I upload the program to the board it only displays the first potentiometer value (A0).
//Analog Read with Serial Monitor
  Serial.begin(9600); //initialize serial communication at 9600 bits per second
  int RsensorValue = analogRead(A0);
  int GsensorValue = analogRead(A1);
  int BsensorValue = analogRead(A2);
  Serial.println(RsensorValue); //print out the value you read
  Serial.println(GsensorValue);
  Serial.println(BsensorValue);
  delay(100); //delay in between reads for stability
What happens when you do this:
  // int RsensorValue = analogRead(A0);
  // int GsensorValue = analogRead(A1);
  // Serial.println(RsensorValue); //print out the value you read
  // Serial.println(GsensorValue);
What Arduino are you running this code on?
Steve
You can see much better what happens if you print the values on separate lines:
  Serial.print(F("R: "));
  Serial.print(RsensorValue); //print out the value you read
  Serail.print(F(", G: "));
  Serial.print(GsensorValue);
  Serial.print(F(", B: "));
What is the source of your input signal?
Try moving the delay between reads, you are reading the A/D to fast, it needs a bit of settling time for each read. I would interleave the sensor read then the sensor display color by color. This response is to help you get started in solving your problem, not solve it for you.
Good Luck & Have Fun!
Gil
gilshultz:
This isn't true. If the pots are 50k or lower then it will be perfectly fine reading them as fast as you can in turn without crosstalk, as the maximum impedance seen is 12.5k which is good enough (10k or less is ideal).
Even if the impedance is very high such that crosstalk is occuring simply waiting will not work, you have to do multiple analogReads with the same pin number to pre-charge the sample/hold capacitor, as the first read connects the S/H cap to the pin, the subsequent reads get the benefit of settling time.
If the input impedance to the analog pin is much above 10k, read the pin twice, discarding the first value.
If the input impedance is 10k or so or less, one analogRead() is always enough.
Gil
