Hi all,
I am rather new to Arduino programming and would like your guidance on a problem I am facing with writing and reading structs to EEPROM using put/get.
Here is a brief overview of what I am trying to do:
I have added an OLED screen to a Pro Trinket board (ATmega 328) and am trying to create a simple sketch that adds/browses todo items. The user inputs the text using a 5-way navigation switch and he can later on scroll through the items. Each item has an id, a title and the content.
Here is how I declared my struct:
typedef struct Todo {
uint8_t id;
char title[10];
char todo_content[20];
And here is the function that handles the text input:
void text_input(char input[], char *temp)
uint8_t position = 0;
uint8_t i;
oled.clearDisplay();
display_text("Enter text",1,0,0);
while( 1 == 1 )
if (digitalRead(BTN_UP) == LOW)
if( input[position] < 127 )
input[position] = input[position]+1;
delay(MENU_DELAY);
if (digitalRead(BTN_DOWN) == LOW)
if( input[position] > 33 )
input[position] = input[position]-1;
delay(MENU_DELAY);
if (digitalRead(BTN_RIGHT) == LOW)
if( position < strlen(input)-1 )
position++;
delay(MENU_DELAY);
if (digitalRead(BTN_LEFT) == LOW)
if( position > 0 )
position--;
delay(MENU_DELAY);
if (digitalRead(BTN_CLICK) == LOW)
return;
for( i = 0; i < strlen(input); i++)
if( position == i )
oled.setTextSize(2);
oled.setTextColor(BLACK,WHITE);
oled.setCursor((i*12)+1,17);
oled.println(input[i]);
oled.setTextColor(WHITE,BLACK);
temp[i] = input[i];
oled.display();
where input is the initial text (sample text) and temp is the char array to fill (since I cannot return a char array from a function as I found out). Ignore the oled* and display_text() stuff, it is used to output to the screen.
Now here is the function that stores the struct:
void on_menu_add(MenuComponent* p_menu_component)
display_text("Add item",1,0,0);
char temp[11];
text_input("my todo", temp);
Todo new_todo = {
1,
"get milk",
temp
EEPROM.put( EEPROM.read(TODO_CNT)+20, new_todo);
As you can see, I am trying to use the temp variable, filled by the text_input function in the struct, which I later write to the EEPROM using EEPROM.put.
However, this does not seem to be working exactly as I thought (seasoned Arduino programmers probably already know what I am doing wrong...) since if I use EEPROM.get like so:
void on_menu_browse(MenuComponent* p_menu_component)
Todo get_todo;
EEPROM.get(20, get_todo);
oled.setTextSize(1);
oled.setTextColor(WHITE);
oled.setCursor(0,0);
oled.println(get_todo.id);
oled.setCursor(0,9);
oled.println(get_todo.title);
oled.setCursor(0,17);
oled.println(get_todo.content);
oled.display();
delay(4000);
I can get the id and title, but not the content, which comes as a single garbage like character (using strlen() reports a length of 1 too).
I am 90% certain I am doing something wrong while creating the struct, but I can't figure out what it is. If anyone can point me in the right direction, that would be great!
P.S. Pro Trinket does not have a Serial monitor, so I can only debug by writing stuff on the screen...
