Trouble regarding usage of TMP36 sensor
I am using a TMP36 temperature sensor along with Arduino Uno to display the temperature on the Serial Monitor. It displays the temperature, but it is gibberish, such as -19 C and -25 C. I have modified my code several time to resolve the discrepancy, but without success. Here's my code:-
const int temp=14;
pinMode(temp,INPUT);
int reading;
reading=analogRead(temp);
float voltage;
voltage=(reading*5);
voltage=voltage/1024;
float sense;
sense=(voltage-0.5)*100;
Serial.print(sense);
Serial.println(" C ");
Please try to help me resolve the error over here.
maybe you should use A0 instead of 14?
furthermore you can shorten your code a bit by combining expressions.
const int temp=A0;
  int reading = analogRead(temp);
  float voltage = reading*5.0 / 1024;
  float sense = (voltage-0.5) * 100;
Try this with the sensor output connected to A1.
Leo..
// TMP36 temp sensor connected to Analogue-in 1, +5volt and ground
// ~-50 to ~+150 degrees C
unsigned int total;
float tempC;
float tempF;
  //analogReference(INTERNAL2V56); // ---uncomment this line is for a MEGA---
  Serial.begin(9600); // set serial monitor to this value
  analogRead(1); // one unused reading
  for (int x = 0; x < 20; x++) { // 20 readings for averaging
    total = total + analogRead(1); // add each value to a total
  Serial.print("Raw average = "); // debugging
  Serial.print(total * 0.05, 1); // 1/20 of 20 readings, one decimal place
  // leave ONE of these three lines uncommented
  //tempC = total * 3.3 * 5 / 1024 - 50; // ---this line is for 3.3volt Arduinos---
  tempC = total * 5.0 * 5 / 1024 - 50; // ---this line is for 5volt Arduinos---
  //tempC = total * 2.56 * 5 / 1024 - 50; // ---this line is for a MEGA with 2.56volt Aref enabled---
  // calibration: change voltages to actual voltage for accurate temps, e.g. 5.0 to 5.136
  tempF = tempC * 1.8 + 32; // Fahrenheit conversion
  Serial.print("   The temperature is  ");
  Serial.print(tempC, 1); // one decimal place
  Serial.print(" Celcius  ");
  Serial.print(tempF, 0); // no decimal place
  Serial.println(" Fahrenheit");
  delay(1000); // slows readings
  total = 0; // reset value
