Trouble reviving an AtMega 168 with STK500 Clone
Hey guys,
I've got a Romeo board which was working great until I loaded a sketch which was to big for memory. Ever since then it doesn't respond to USB programming (though the FTDI is recognised).
I picked up an STK500 clone programmer and used AVR Studio to burn one of the bootloaders - that seemed to work fine (though it's the first time I've ever done that) but the board still isn't responding to USB.
Is there a way, in windows, to upload a sketch via the ISP programmer? If I can get a blink sketch running then at least I know it's still working and it could be the FTDI connection.
Does anyone have any ideas?
Cheers,
Miles
if you clear out your applet folder and then attempt an upload in the arduino ide, it will build a hex file that you can write with an isp programmer and avrdude
what errors were you getting with the isp programmer you have?
Via usb I get STK500 timeout.
STK500 ISP programmer works fine.
So if I compile blink as you suggested I can burn that into the flash - does that include the bootloader to upload it?
FYI:
also, I had an issue with what avrdude said was correct with the efuse vs what i had to write. check that out here
basically the efuse has to be 0 instead of the f8 that it wants to write
Hmm, per your guide I droped back from F8 to 0 and I got:
Writing fuses address 0 to 2.. 0xFF, 0xDF, 0x00 .. OK!
Reading fuses address 0 to 2.. 0xFF, 0xDF, 0xF8 .. OK!
WARNING: Fuse bits verification.. FAILED
Leaving programming mode.. OK!
i know that the f8 to 0 is for avrdude which was where i was writing it. im not sure / have not used avr studio. if it writes the bootloader correctly with f8 instead of the 0, then you should probably use that when writing the blink hex
That seemed to work great. I've tried to upload a sketch and, alas, it still doesn't work
Could not delete H:\arduino-0017\examples\Digital\Blink\applet
Binary sketch size: 896 bytes (of a 14336 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
Adding some more mystery to this problem. I've uploaded the "Serial Communications" sketch to rule out a FUBAR FTDI connection. Nope, it works great. Communication is two-way - very strange.
Could the lack of auto-reset cause the STK500 (within the 168 bootloader) to void an upload?
Hey guys,
With some trial-and-error I managed to finally figure out what was up. I'm pretty sure the problem started with a sketch which used up all the RAM on the device which led it do commit suicide.
The reason why the Romeo did not take to the bootloaders I loaded was down to corrupt fuses. Though you could load sketches and/or bootloaders it still wasn't responding. I believe this was a clock issue!
With another Arduino on hand, specifically a Seeeduino clone (168) I decided to verify my hypothesis by nuking it. It did exactly what I expected. I reverted it back to it's original settings and moved onto the Romeo.
I accidentally managed to slow the clock down yet further. Using AVR Studio I set the read clock speed to 140~ Hz and went about setting the fuses (etc) to the following:
I then burnt the seeeduino bootloader, to be consistant, to the Romeo. It all came alive!
We're back in business :wink: Hopefully this will help someone
