Trouble running on amd64 ubuntu
Hi, when I run make.sh, I get some warnings, but it compiles. Then when I run “run.sh”, it says
[: 51: ==: unexpected operator
and then yells at me about whether I have jikes installed. I’ve installed the latest tarball of jikes (1.22), so that’s definitely not it. Any ideas what I can do to make arduino run properly?
See this thread: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1163538117/1#1
I just fixed this, so the correct script should be in the Arduino 0007 release.
I added the code you submitted, and now I just get:
[: 52: ==: unexpected operator
Hmm. Your run.sh file should just look like this:
#!/bin/sh
cd work && ./arduino && cd ..
and your work/arduino file should be:
#!/bin/sh
CLASSPATH=java/lib/rt.jar:lib:lib/build:lib/pde.jar:lib/core.jar:lib/antlr.jar:lib/oro.jar:lib/registry.jar:lib/mrj.jar:lib/RXTXcomm.jar
export CLASSPATH
# put the directory where this file lives in the front of the path, because
# that directory also contains jikes, which we will need at runtime.
PATH=`pwd`/`dirname $0`:`pwd`/java/bin:${PATH}
export PATH
# put the directory with the native RXTX libs in the library path
LD_LIBRARY_PATH=`pwd`/lib:${LD_LIBRARY_PATH}
export LD_LIBRARY_PATH
java processing.app.Base
I'm not sure where the == would be coming from. Any idea?
After the update to my work/ardino it works like a dream. Thanks!
