Trouble saving JPEG images to SD card
Hey guys, I'm a beginner programmer who is in a weather balloon project. I have programmed some sensors before but my launch date is in 2 more days and I've been working on this for hours upon hours. The farthest I have gotten with some sample code is a JPEG file on the SD card but wont open due to "this is not a valid bitmap file, or it's format is not currently supported".
Here is the camera im using: Tutorial of Using LinkSprite 2MP UART JPEG Camera with Arduino | LinkSprite Learning Center
The sample code on that website is almost identical to the one im using on the Arduino IDE except I've made changes for the code to run on hardware serial for a WF32. The hexadecimal data is being saved to the file correctly however I believe the data itself may have a few problems in the first line. I'll attach a notepad of the hexadecimal.
This may look like a lot to do just to help some noob but getting this working is VERY important to me and I really appreciate any help, thanks.
hexadecimal serial monitor.txt (37.4 KB)
Please read how to use this forum thread: http://forum.arduino.cc/index.php?topic=149015.0
You haven't posted:
  • Your code
  • The bad JPEG file
  • What a WF32 is
We need to know things like this to help you.
Thanks for the heads up.
Code:
 // LinkSprite.com
  // Note:
  // 1. SD must be formated to FAT16
  // ***2. As the buffer of softserial has 64 bytes, so the code read 32 bytes each time
  // 3. Please add the libaray to the lib path
  //  * SD card attached to SPI bus as follows:
  //  MOSI - pin
  //  MISO - pin
  //  CLK - pin
  //  SS - pin 51
  #include <SD.h>
  const int chipSelect_SD_default = 51;
  const int chipSelect_SD = chipSelect_SD_default;
  byte ZERO = 0x00;
  byte incomingbyte;
  #define mySerial Serial1          // Set Arduino pin 4 and 5 as softserial
  long int a=0x0000,j=0,k=0,count=0,i=0;
  uint8_t MH,ML;
  boolean EndFlag=0;
  File  myFile;
  void SendResetCmd();
  void SetBaudRateCmd();
  void SetImageSizeCmd();
  void SendTakePhotoCmd();
  void SendReadDataCmd();
  void StopTakePhotoCmd();
    Serial.begin(38400);
    Serial1.begin(38400);
    mySerial.begin(38400);
    Serial.print("Initializing SD card...");
    // On the Ethernet Shield, CS is pin 4. It's set as an output by default.
    // Note that even if it's not used as the CS pin, the hardware SS pin
    // (10 on most Arduino boards, 53 on the Mega) must be left as an output
    // or the SD library functions will not work.
    // pinMode(10, OUTPUT);
    // pinMode(chipSelect_SD_default, OUTPUT);
    // digitalWrite(chipSelect_SD_default, HIGH);
    pinMode(chipSelect_SD, OUTPUT);
    digitalWrite(chipSelect_SD, HIGH);
    if (!SD.begin(chipSelect_SD)) {
      Serial.println("initialization failed!");
      return;
    Serial.println("initialization done.");
    byte a[32];
    int ii;
    SendResetCmd();
    delay(4000);                            //Wait 2-3 second to send take picture command
    SendTakePhotoCmd();
    while(mySerial.available()>0)
      incomingbyte=mySerial.read();
    myFile = SD.open("pic.jpg", FILE_WRITE); //<strong><span style="color: #ff0000;">The file name should not be too long</span></strong>
      while(!EndFlag)
        j=0;
        k=0;
        count=0;
        SendReadDataCmd();
        delay(20); //250 for regular
          k++;
          if((k>5)&&(j<32)&&(!EndFlag))
            a[j]=incomingbyte;
            if((a[j-1]==0xFF)&&(a[j]==0xD9))     //tell if the picture is finished
              EndFlag=1;
            j++;
            count++;
        for(j=0;j<count;j++)
          if(a[j]<0x10)
            Serial.print("0");
          Serial.print(a[j],HEX);           // observe the image through serial port
          Serial.print(" ");
        for(ii=0; ii<count; ii++)
          myFile.write(a[ii]);
        i++;
    myFile.close();
    Serial.print("Finished writing data to file");
    while(1);
  void SendResetCmd()
    mySerial.write(0x56);
    mySerial.write(ZERO);
    mySerial.write(0x26);
    mySerial.write(0x31);
    mySerial.write(0x05);
    mySerial.write(0x04);
    mySerial.write(0x01);
    mySerial.write(0x19);
    mySerial.write(0x11);
    mySerial.write(0x24);
    mySerial.write(0x03);
    mySerial.write(0x2A);
    mySerial.write(0xC8);
    mySerial.write(0x36);
    MH=a/0x100;
    ML=a%0x100;
    mySerial.write(0x32);
    mySerial.write(0x0c);
    mySerial.write(0x0a);
    mySerial.write(MH);
    mySerial.write(ML);
    mySerial.write(0x20);
    a+=0x20;
I'm using a chipkit WF32 microprocessor but programming on the Arduino IDE.
I'll attach the bad JPG file.
PIC.JPG|0x0
How? the WF32 uses a PIC micro controller.
Mark
Sorry, you are correct. It's PIC micro controller but the actual board is a WF32.
I'm going to be working on this literally all day so if anyone as questions to ask please feel free. If you look at the hexadecimal the return address 76 00 32 00 00 is being printed before the start of the file FF D8. I'm not sure if that's supposed to be there along with the 5 bytes FE 00 24 5F 00 in between FF and E0.
