Hello All!
I am working on a program where the microcontroller (Adafruit Feather 32u4 Bluefruit LE) collects data from an IMU sensor (Adafruit 9-DOF BNO055) and sends it to my phone via Bluetooth. The microcontroller gets good data from the sensor but I am failing to send the data to my phone via Bluetooth. I can only view the data on an Arduino serial monitor. Here is the code I am using.
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BNO055.h>
#include <utility/imumaths.h>
#include <Arduino.h>
#include <SPI.h>
#if not defined (_VARIANT_ARDUINO_DUE_X_) && not defined (_VARIANT_ARDUINO_ZERO_)
#include <SoftwareSerial.h>
#endif
#include "Adafruit_BLE.h"
#include "Adafruit_BluefruitLE_SPI.h"
#include "Adafruit_BluefruitLE_UART.h"
#include "BluefruitConfig.h"
/* Set the delay between fresh samples */
#define FACTORYRESET_ENABLE 1
#define MINIMUM_FIRMWARE_VERSION "0.6.6"
#define MODE_LED_BEHAVIOUR "MODE"
#define SEND_SECOND_PLOT 0
Adafruit_BluefruitLE_SPI ble(BLUEFRUIT_SPI_CS, BLUEFRUIT_SPI_IRQ, BLUEFRUIT_SPI_RST);
#define BNO055_SAMPLERATE_DELAY_MS (100)
Adafruit_BNO055 bno = Adafruit_BNO055();
void error(const __FlashStringHelper*err) {
Serial.println(err);
while (1);
void setupp (void)
// while (!Serial); // required for Flora & Micro
Serial.println(F("Adafruit Bluefruit Command <-> Data Mode Example"));
Serial.println(F("------------------------------------------------"));
/* Initialise the module */
Serial.print(F("Initialising the Bluefruit LE module: "));
if ( !ble.begin(VERBOSE_MODE) )
error(F("Couldn't find Bluefruit, make sure it's in CoMmanD mode & check wiring?"));
Serial.println( F("OK!") );
if ( FACTORYRESET_ENABLE )
/* Perform a factory reset to make sure everything is in a known state */
Serial.println(F("Performing a factory reset: "));
if ( ! ble.factoryReset() ) {
error(F("Couldn't factory reset"));
/* Disable command echo from Bluefruit */
ble.echo(false);
Serial.println("Requesting Bluefruit info:");
/* Print Bluefruit information */
ble.info();
Serial.println(F("Please use Adafruit Bluefruit LE app to connect in UART mode"));
Serial.println(F("Then Enter characters to send to Bluefruit"));
ble.verbose(false); // debug info is a little annoying after this point!
/* Wait for connection */
while (! ble.isConnected()) {
Serial.println(F("******************************"));
// LED Activity command is only supported from 0.6.6
if ( ble.isVersionAtLeast(MINIMUM_FIRMWARE_VERSION) )
// Change Mode LED Activity
Serial.println(F("Change LED activity to " MODE_LED_BEHAVIOUR));
ble.sendCommandCheckOK("AT+HWModeLED=" MODE_LED_BEHAVIOUR);
// Set module to DATA mode
Serial.println( F("Switching to DATA mode!") );
ble.setMode(BLUEFRUIT_MODE_DATA);
void setup(void)
Serial.println("Orientation Sensor Raw Data Test"); Serial.println("");
/* Initialise the sensor */
if(!bno.begin())
/* There was a problem detecting the BNO055 ... check your connections */
Serial.print("Ooops, no BNO055 detected ... Check your wiring or I2C ADDR!");
while(1);
/* Display the current temperature */
int8_t temp = bno.getTemp();
Serial.print("Current Temperature: ");
Serial.print(temp);
Serial.println(" C");
Serial.println("");
bno.setExtCrystalUse(true);
Serial.println("Calibration status values: 0=uncalibrated, 3=fully calibrated");
void loop(void)
// Possible vector values can be:
// - VECTOR_ACCELEROMETER - m/s^2
// - VECTOR_MAGNETOMETER - uT
// - VECTOR_GYROSCOPE - rad/s
// - VECTOR_EULER - degrees
// - VECTOR_LINEARACCEL - m/s^2
// - VECTOR_GRAVITY - m/s^2
imu::Vector<3> euler = bno.getVector(Adafruit_BNO055::VECTOR_ACCELEROMETER);
sensors_event_t event;
bno.getEvent(&event);
Serial.print("X (orientation): ");
Serial.print(event.orientation.x, 4);
Serial.print("\tY (orientation): ");
Serial.print(event.orientation.y, 4);
Serial.print("\tZ (orientation): ");
Serial.print(event.orientation.z, 4);
ble.print("X (orientation): "); /* This is the line the data is meant to be sent via Bluetooth (To see the data comment this line and the one below it)*/
ble.print(event.orientation.x, 4);
/* Display the floating point data */
Serial.print("\t\tX (acc): ");
Serial.print(euler.x());
Serial.print("Y (acc): ");
Serial.print(euler.y());
Serial.print("Z (acc): ");
Serial.print(euler.z());
Serial.print("\t\t");
// Quaternion data
imu::Quaternion quat = bno.getQuat();
Serial.print("qW: ");
Serial.print(quat.w(), 4);
Serial.print(" qX: ");
Serial.print(quat.y(), 4);
Serial.print(" qY: ");
Serial.print(quat.x(), 4);
Serial.print(" qZ: ");
Serial.print(quat.z(), 4);
/* Display calibration status for each sensor. */
uint8_t system, gyro, accel, mag = 0;
bno.getCalibration(&system, &gyro, &accel, &mag);
Serial.print("CALIBRATION: Sys=");
Serial.print(system, DEC);
Serial.print(" Gyro=");
Serial.print(gyro, DEC);
Serial.print(" Accel=");
Serial.print(accel, DEC);
Serial.print(" Mag=");
Serial.println(mag, DEC);
delay(BNO055_SAMPLERATE_DELAY_MS);
