Trouble sending IR volume control using Arduino
Hello
I am currently trying to make a simplified IR remote control device for my McIntosh C2300 preamp.
I am using an arduino and the IRemote library.
The preamp uses the NEC protocol and, using IRrecvDump, I got the following codes for the keys I need:
Vol+
Decoded NEC: 53AA43BC (32 bits)
Vol-
Decoded NEC: 53AAC33C (32 bits)
Mute
Decoded NEC: 53AA639C (32 bits)
D/A
Decoded NEC: 53AAC936 (32 bits)
Tuner
Decoded NEC: 53AA49B6 (32 bits)
Power
Decoded NEC : 53AA03FC (32 bits)
Using the irsend.sendNEC() from the same library and an IR LED, I can send control the preamp to power on/off, mute and change inputs without any problem.
But I can't manage to change volume up or down, no matter if I send the command repeatedly and/or I use the repeat argument :
irsend.sendNEC(0x53AA43BC , 32, 3);
I also have the D100 DAC from the same brand, which has a volume control which works properly when provided the appropriate codes.
I also tried with an ESP32 with the no better results.
Any idea?
Thanks in advance.
