Hello all. I am working on a project that involves sending POST requests to a Twilio function using an Arduino Uno and a SIMCOM SIM7000A breakout board using AT commands. So far with the Uno, I can only POST an empty request that contains headers but no body. The following code is a test sketch where I am POSTing to a RequestBin repository.
#include <AltSoftSerial.h>
unsigned char data = 0;
AltSoftSerial SIM7000;
char incomingChar;
SIM7000.begin(19200);
SIM7000.print("AT+CMGF=1\r"); //put in text mode
delay(100);
SIM7000.print("AT+CGDCONT=1\"IP\",\"super\"\r"); //create profile. "super" is APN for twilio super sim
SIM7000.print("AT+COPS=1,2,\"310410\"\r"); //log on to AT&T network
delay(5000);
SIM7000.print("AT+SAPBR=3,1,\"APN\",\"super\"\r"); //create SAPBR profile. same APN.
delay(300);
SIM7000.print("AT+SAPBR=1,1\r");
delay(2000);
Serial.println("Setup complete. Module should be online and fast-blinking\n from successful SAPBR profile setup.\n Entering loop. Send \"CHECK\" to test POST");
SIM7000.print("AT+CMGL\r");
if (SIM7000.available() > 0) {
incomingChar = SIM7000.read();
if (incomingChar == 'C') {
delay(10);
Serial.print(incomingChar);
if (incomingChar == 'H') {
delay(10);
if (incomingChar == 'E') {
delay(10);
delay(10);
if (incomingChar == 'K') {
delay(10);
incomingChar = "";
Serial.println(F("\nGOOD CHECK"));
Serial.println(F("SENDING POST REQUEST NOW")) ;
sendText();
Serial.println("POST SENT");
return;
incomingChar = "";
return;
void sendText()
SIM7000.print("AT+HTTPINIT\r");
getResponse();
SIM7000.print("AT+HTTPPARA=\"CID\",1\r");
getResponse();
SIM7000.print("AT+HTTPPARA=\"URL\",\"http://engt62k9mgbgo.x.pipedream.net\"\r");
getResponse();
SIM7000.print("AT+HTTPPARA=\"CONTENT\",\"text/plain\"\r");
getResponse();
SIM7000.print("AT+HTTPDATA=100,5000\r\n");
delay(100);
getResponse();
SIM7000.print("\"TEST MESSAGE\"\r\n");
SIM7000.print("\r\n");
delay(5000);
getResponse();
SIM7000.print("AT+HTTPACTION=1\r");
getResponse();
SIM7000.print("AT+HTTPTERM\r");
getResponse();
void getResponse()
if (SIM7000.available())
while (SIM7000.available())
data = SIM7000.read();
Serial.write(data);
data = 0;
//NOV 3 2020, note: need to include AT command AT+CMGD=0,4 for routinely deleting messages
//message storage limited and not automatically overwritten
I've attached the output on the Serial monitor titled "Test POST output.JPG".
I'm thinking that the problem lies between
and
You can see on the output where it prompts for DOWNLOAD, but the "TEST MESSAGE" that I try to insert here doesn't go. I've also attached a screenshot of the RequestBin output to show that it's showing up as an empty POST with nothing but headers and a content length of 0.
When I've done similar POST requests using the same SIM7000A module with the same AT commands on PuTTY via USB, all I have to do is enter my text during the time specified in the AT+HTTPDATA command and hit enter. Whatever I enter during that time as it says "DOWNLOAD" shows up as the body of my POST. But I have as of yet been unable to do the same using the Uno.
Any help you can offer is much appreciated.
