Trouble setting up Arduino Pro Mini
I have an Arduino Pro mini connected to a Bluesmirf, which acts as the serial port with my computer's bluetooth serial port. I can pair the bluetooth fine with the computer, but when I try to upload the PhysicalPixel example below, my bluesmirf breaks off from its pairing with the computer. Has anyone done something similar? What could be the problem?
int outputPin = 13;
int val;
  pinMode(outputPin, OUTPUT);
  if (Serial.available()) {
    val = Serial.read();
    if (val == 'H') {
      digitalWrite(outputPin, HIGH);
    if (val == 'L') {
      digitalWrite(outputPin, LOW);
How do you have them wired?
ok here is how I did it:
I have the same issue! I can't make it work. I have spent the entire day with it, no success at all.
I think I have tried everything!! My code is a copy paste of this tutorial: http://www.arduino.cc/playground/Learning/Tutorial01
The only way I can make the Arduino Pro Mini to work is by connecting it via USB to my other Arduino board as explained here: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1248295911
Once I remove the cables and just change it to a battery and to the RAW pin, it stops working!! I am so disapointed, frustrated and sad...
Please help!!!!
YAAAYYY!!!!!! IT WORKS!!!! HAHAHAHAHA
I finally figured it out by myself and thanks to this post: http://tryingtodotheprojects.blogspot.com/2007/12/arduino-over-bluetooth.html
The stupid BlueSmirfs come with a default set up of their Baud rates at 115200!!! And the Arduino Pro Mini was looking for a 9600... Got it fixed by using Teraterm and changing the BlueSmirf's baud rate as explained in the link above.
OMG i can't believe I made it work!! It's been an entire day, and I knew from the first test that it was the stupid baud rate, just couldn't make the Teraterm to work properly.
I hope this helps someone in the future. I'm so happy!
How are you? I would like to Thanks for the informative post. I really appreciate it. I hope that I can get more benefit from this topic.
Thanks
