Trouble Setting up MKR WAN1310 on Arduino Cloud
I bought a dragon gateway and configured it on TTN. Now I am trying to setup and use a MKR WAN1310 on the Arduino cloud. I found this guide and followed the steps. https://docs.arduino.cc/arduino-cloud/getting-started/cloud-lora-getting-started
I get as far as number 8 of step 1 in the guide. 8. Now, you will need to give your board a good name, such as LoRa ine, WAN da or GLoR ia (feel free to ignore this advice). Click on "Next" to start the configuration.
I configure device and it never gets past uploading sketch, before it finishes it says the device is not available. I tried resetting the device by pushing the reset button twice, have shut down my PC and neither have worked.
I have configured Wifi modules before and if I had troubles hitting the reset button twice has always seemed to fix it. Does anyone know what I am missing or doing wrong?
Below is the message I see in the connect debug window. Does the isOpen:false, mean the serial port is not open or the board is not open? I have tried doing this with 2 different boards that are both brand new now and get the same results.
Serial Ports:
"Name": "/dev/cu.usbmodem141201",
"SerialNumber": "",
"IsOpen": false,
"VendorID": "0x2341",
"ProductID": "0x0053"
I still have not got it configured or working, but I answered my own question in regards to the serial port debugging. I configuired a new wfi module and noticed the serial port IsOpen also said false. I am wondering if anyone else has been able to configure a MKR1300 or MKR 1310 today? Is there any known issue between Arduino and TTN right now?
Thanks
I have a MKR 1300 and I have the same issue. It sees the device, gives it a name, then says no device is connected. It seems like this has been going on for more than a week.
Thanks for the response. I hope they get it fixed soon because I just started paying for the business enterprise account and am paying for nothing until I can get these 12 boards setup and running.
Hello there,
we just fixed a couple of issues on our side. Can you please try again and let us know?
Still not working. Someone from tech support emailed me as well. They were able to delete the 2 boards from TTN for me and asked me to try again. I tried both a 1310 and 1300 and both registered on TTN again, but not in Arduino IOT, again. I did get a different error message this time on Arduino IOT though. See below, I got similar message for both, they just had different device id in the message.
Hello @tlampher ,
looks like you are trying to add an Arduino MKR WAN into an Organization.
We have a bug on our side, and we are on it. Will update you with an ETA soon.
Using the personal account there shouldn't be issues.
The bug should be solved.
Please let me know if you see any other issue.
