Trouble Shooting Arduino Errors
I am running the following code and getting the errors shown below the code but am unsure as to why these errors are happening.
Arduino Code:
int AccelXValue = 0;
  int AccelYValue = 0;
  int AccelZValue = 0;
  float Vector[3] = {0.0, 0.0, 0.0};
int GetAccelXValue(AccelXValue)
if (AccelXValue == 0) {
return (float) 1.1;}
int GetAccelYValue(AccelYValue){
if (AccelYValue == 0){
  return (float) 2.2;}}
int GetAccelZValue(AccelZValue){
if (AccelZValue == 0) {
  return (float) 3.3;}}
  AccelXValue = GetAccelXValue();
  AccelYValue = GetAccelYValue();
  AccelZValue = GetAccelZValue();
float X = AccelXValue * AccelXValue;
float Y = AccelYValue * AccelYValue;
float Z = AccelZValue * AccelZValue;
float magnitude = X + Y + Z;
float A = AccelXValue/magnitude;
float B = AccelYValue/magnitude;
float C = AccelZValue/magnitude;
Vector = [A, B, C];
Serial.println(Vector);
errors given:
Part_2_2_2.ino: In function ‘void loop()’:
Part_2_2_2:13: error: expected ‘,’ or ‘;’ before ‘{’ token
Part_2_2_2:44: error: expected `}’ at end of input
I can not figure out why I am getting these errors. If anyone knows of a solution that would be great.
thank you
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
This code can compile :
float Vector[3] = {
  0.0, 0.0, 0.0};
int GetAccelXValue(int AccelXValue){
    return (float) 1.1; // this is float  should be int.
  }else{
     return 0; // or some int
You omit final bracket in loop and
int GetAccelXValue(int AccelXValue) did not have data type for AccelXValue parametar.
It looks like you are putting function definitions inside of loop(). I don't think the compiler likes that.
