I am trying to get the mp3 shield to play when the piezo element senses vibration and this code does that but only for a quick second rather than for 1min 30 seconds like its supposed to. It shows error code 1. Can anyone help?
Sketch assumes you have MP3 files with filenames like “track001.mp3”,
“track002.mp3”, etc on an SD card loaded into the shield.
#include <SPI.h>
//Add the SdFat Libraries
#include <SdFat.h>
#include <FreeStack.h>
//and the MP3 Shield Library
#include <SFEMP3Shield.h>
// Below is not needed if interrupt driven. Safe to remove if not using.
#if defined(USE_MP3_REFILL_MEANS) && USE_MP3_REFILL_MEANS == USE_MP3_Timer1
#include <TimerOne.h>
#elif defined(USE_MP3_REFILL_MEANS) && USE_MP3_REFILL_MEANS == USE_MP3_SimpleTimer
#include <SimpleTimer.h>
#endif
SdFat sd; //SD object
SFEMP3Shield MP3player; //Shield object
unsigned long startPlay; //This stores the last millisecond since we had a vibration
//const unsigned int playTime = 90000;//seconds * 1000 length of play in milliseconds
const long playTime = 90000;//seconds * 1000 length of play in milliseconds
int vibration = -1;
const int knockSensor = A0; // the piezo is connected to analog pin 0
const int threshold = 100; // threshold value to decide when the detected sound is a knock or not
// these variables will change:
int sensorReading = 0; // variable to store the value read from the sensor pin
char trackName = “track001.mp3”;
uint8_t result; //result code from some function as to be tested at later time.
Serial.print(F("F_CPU = "));
Serial.println(F_CPU);
Serial.print(F(“Free RAM = “));
Serial.print(FreeStack(), DEC); // FreeStack() is provided by SdFat
Serial.println(F(” Should be a base line of 1028, on ATmega328 when using INTx”));
//Initialize the SdCard.
if (!sd.begin(SD_SEL, SPI_FULL_SPEED)) sd.initErrorHalt();
if (!sd.chdir("/")) sd.errorHalt(“sd.chdir”);
//Initialize the MP3 Player Shield
result = MP3player.begin();
//check result, see readme for error codes.
if (result != 0) {
Serial.print(F(“Error code: “));
Serial.print(result);
Serial.println(F(” when trying to start MP3 player”));
if ( result == 6 ) {
Serial.println(F(“Warning: patch file not found, skipping.”)); // can be removed for space, if needed.
Serial.println(F(“Use the “d” command to verify SdCard can be read”)); // can be removed for space, if needed.
// Below is only needed if not interrupt driven. Safe to remove if not using.
&& ( (USE_MP3_REFILL_MEANS == USE_MP3_SimpleTimer)
|| (USE_MP3_REFILL_MEANS == USE_MP3_Polled) )
MP3player.available();
#endif
while (vibration == -1)
sensorReading = analogRead(knockSensor);
// if the sensor reading is greater than the threshold:
if (sensorReading >= threshold) {
startPlay = millis();
playAction(1);
vibration = 1;
//check if sufficient
while (vibration == 1) {
if (millis() - startPlay > playTime) {
there is still vibration,restart playback and reset timer
playAction(1);
no vibration, pause playing, reset sentinel
else {
vibration = -1;
playAction(2);
delay(100);
\1 to play 2 to pause
void playAction(int command) {
if (command == 1) {
//create a string with the filename
//tell the MP3 Shield to play that file
result = MP3player.playMP3(trackName);
if (result != 0) {
Serial.println(F(” when trying to play track”));
/* Display the file on the SdCard */
if ( MP3player.getState() == playback) {
MP3player.pauseMusic();
Serial.println(F(“Pausing”));
Serial.println(F(“Not Playing!”));
