Trouble shooting push button
Hi guys
I'm trying to write a code that makes an LED light up until the button is pressed. Once the button is pressed I want the light to blink 3 times and then stay off. I've tried every combination of if, while, else, etc. but I cant get it to do what I want.
I do need the for statement in there because this is just a proof of concept for another project I'm working on that requires it.
Any help or suggestions are much appreciated.
push_button_trouble.ino (662 Bytes)
Any good reason for not posting code?
Any good reason for posting this in "Installation and troubleshooting"?
Pretty simple:
const int  buttonPin = 2;    // the pin that the pushbutton is attached to
const int ledPin = 13;       // the pin that the LED is attached to
  // initialize the button pin as a input:
  pinMode(buttonPin, INPUT_PULLUP);
  // initialize the LED as an output:
  pinMode(ledPin, OUTPUT);
  // Turn LED on.  It will stay on until the button is pressed
  digitalWrite(ledPin, HIGH);
  // if the state has changed, increment the counter
  if (digitalRead(buttonPin) == LOW)
    for (int i = 0; i < 3; i++)
      digitalWrite(ledPin, LOW);
    while (1);
