Hi Everyone,
I'm building a large battery for solar energy storage, and trying to use an Arduino Nano to read data from the battery management system through the UART port. So far, I've successfully initiated the serial connection with the BMS, sent it a request for information, read that information, and printed it to the serial monitor. No small feat for a rube like myself... Where I'm struggling is getting the BMS output saved to a string (or array) so that i can then process it.
Here's the code I've used to successfully get temperature readings from the BMS:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
int inByte; //Variable for incoming serial values
Serial.begin(115200); // Open serial communication to computer
Serial.println("Serial Started");
mySerial.begin(115200); // Open serial communication to BMS
mySerial.write(0xAA); //Send temperature readings request to BMS
mySerial.write(0x1B);
mySerial.write(0x3F);
void loop () {
if (mySerial.available() > 0) {
inByte = mySerial.read(); //Reads individual values from softwareSerial buffer
Serial.print(inByte); //Prints the inByte values to serial monitor
Serial.print(" "); //Add a space
The output of this program looks like this (temperature values from three different sensors are highlighted in bold):
14:07:27.192 -> Serial Started
14:07:28.178 -> 170 27 6 167 1 201 0 208 0 248 147
And here's the code I'm using to get this data 'stored' in an array for further processing (mainly based on this).
char inString[100]; //String for incoming serial values
void readData (char *strArray) {
int i = 0; //define index value, set to 0
if(mySerial.available() > 0) {
while(mySerial.available() > 0) {
strArray[i] = mySerial.read(); //write serial buffer content to the string
i++; //increase index value by 1
void printData (char *strArray) {
if(strArray[i] != 0) {
while(strArray[i] != 0) {
Serial.print( strArray[i] ); //print the n = i value of the string
boolean isStringEmpty(char *strArray) { //utility function to know wither an array is empty or not
if (strArray[0] == 0) {
return true;
return false;
mySerial.write(0xAA); //Send request for temp data to BMS
readData(inString);
if( isStringEmpty(inString) == false) {
printData(inString);
delay(5000);
I've tried about a hundred different variants on this, with absolutely no success. In all cases, I just get a bunch of random characters (mostly backwards question marks...).
Any help would be greatly appreciated!
