Hi
I struggle to get ESP8266 recognize my load cell amplifier.
I have 4 pcs 50 kg cells from sparkfun and HX711 from sparkfun.
I have checked and cheked, my connections are OK (99,99% shure).
Serial monitor gives "HX711 not found!"
D2 connected to DAT on hx711
D3 connected to CLK on hx711
I use Generic ESP8266Module version 2.5.0 (latest version gave upload error)
Library HX711 code from GitHub - olkal/HX711_ADC: Arduino library for the HX711 24-bit ADC for weight scales .
I run example from library:
#include "HX711.h"
// HX711 circuit wiring
const int LOADCELL_DOUT_PIN = 3;
const int LOADCELL_SCK_PIN = 2;
HX711 scale;
Serial.begin(57600);
scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
if (scale.is_ready()) {
long reading = scale.read();
Serial.print("HX711 reading: ");
Serial.println(reading);
Serial.println("HX711 not found!");
Any ideas to help me?
horace
June 12, 2022, 10:44am
2
which ESP8266 board do you have
your code is specifing GPIO pins not D2 and D3
looking at a NodeMCU ESP-12E board
D2 connected to DAT on hx711 pin D2 is GPIO4
D3 connected to CLK on hx711 D3 is GPIO 0
rather than specifying GPIO pins try
const int LOADCELL_DOUT_PIN = D2;
const int LOADCELL_SCK_PIN = D3;
Thanks
I dont remember bord type. How can I find it?
I tried, got error:
X711_basic_example:10:31: error: 'D2' was not declared in this scope
It must be somethin else. Im not experienced, so I struggle with this.
Any other ideas to get?
horace
June 12, 2022, 12:26pm
4
do a web search for esp8266 boards and see if you can recognise your board
e.g. does it look like a NodeMCU ESP-12E , see the pinout photo which shows the mapping between D pin numbers and the associated GPIO pin
otherwise upload a photo or a link to where you obained it?
what ESP8266 board do you select on the Arduino IDE?
for now assuming
D3 connected to CLK on hx711 D3 is GPIO0
try
const int LOADCELL_DOUT_PIN = 4; // D2
const int LOADCELL_SCK_PIN = 0; // D4
Hi
so my board is marked D2, D3 etc.
Board type: WIFI Development Board D1 Mini ESP8266 WeMos Wysoka jakość – kup w niskich cenach w sklepie internetowym Joom
Wemos Mini
I changed to
and something positive happened:
After reset I only get Not found
Can it be thet I power HX711 with 5V, and wemos only use 3 V?
horace
June 12, 2022, 1:09pm
6
it looks like a Wemos D1 mini - check the pinout against your board
if you select this board in the Arduino IDE it should define D2 and D3 for you
there appear to be serveral versions of the HX711 - which particular version do you have, e.g. a link to where you obtained it would help
there are also multiple HX711 libraries I assume to match the different HX771 devices
the ESP8266 is a 3.3V device - don't use 5V signals with it
Wawa
June 13, 2022, 1:30am
7
OP mentioned a HX711 from Sparkfun, which is a 3.3volt compatible board.
It has split supplies for analogue and digital.
@Modesty
I assume the analogue supply is connected to 5volt and the digital supply to 3.3volt.
Leo..
horace
June 13, 2022, 5:45am
8
the example programs in the github HX711_ADC library referenced in post #1 include
#include <HX711_ADC.h>
your the code of post #1 includes
#include "HX711.h"
what library are you using ? where did you get it from? are you sure it is suitable for the HX711 board you are using
Hi
Thanks for all help.
The pin 4 and 0 was the main solution. (on board its marked D2 and D3)
I did not figure out bord brand, so used generic ESP8266 board
I use library 711_ADC.h with the sparkfun mondule from Olav Kallhovd
For board manager i installed ESP8266 versjon 2.5.0, version 3.0.2 did not work, upload did not work.
system
Closed
December 10, 2022, 6:17pm
10
