Im just working on a project and want to make it portable without the need of a laptop and USB cord. I've uploaded the simple flashing LED on the arduino board and plugged the USB out ot the arduino. I've hooked up an external 9V battery with an adapter and also tried a 2 AA batteries connected to the Vin and a ground pin.
All i am getting from the arduino itself is the on button on the board is lit green.
Is there anything i need to add to the code before uploading so that it stays on the arduino itself or do i need to boot something on the arduino before i can use it without an external power source.
3 alkaline AAs connected to 5V/Gnd is what you need.
Or 4 rechargeables if they are 1.2V when charged.
3 & 4 AA battery holders available here
Some have an on/off switch.
If you want to use the barrel jack, or Vin, then you need more batteries to overcome the reverse polarity protection diode, and to power the 5V voltage regulator. 6 AAs are enough.
The good thing about using a boost converter is when the battery voltage decrease, due to discharge, the converter holds the output at 5v till the battery voltage goes below 2 volts i.e. for the MT3608.
You can get 10, MT3608 boost converters for about $8.00 USD from eBay.
But as Crossroads has mention there are options . . .
retrotouille:
Two AA batteries in series will give you about 3V. The voltage regulator fed by Vin needs at least 6.2v to get 5V out. The power jack has a diode in series so it needs at least 6.8V.
You can use 3 AA cells in series (4.5V) if you connect through the +5V pin. That doesn't go through the regulator so 4.5V is enough. If you go through the Vin pin, use 5 AA cells in series (7.5V).
Best regards to anyone who can help.
Most boards already come with the flashing LED program installed so no need to upload again.
Either way, did the program run while still plugged in to the USB?
retrotouille:
If you are using an Arduino with native USB, like the Leonardo or Micro, and you have the required
while(!Serial){}
after Serial.begin(), you will find that the sketch hangs there if you don't have the Arduino connected to a USB host. You can change it to
while(!Serial && millis() < 5000){}
to have it continue after five seconds even if no USB host is present.
