Using Serial monitor I send commands to the UNO.
If I send the string "X123Cr" it works well but if I send "XCr" and then "123Cr" only "1" is received.
What am I missing?
The code is too large to attach using code tags. I try to attach the central piece.
Start looking at functiion Figures and case "S". If I then send the string X123 Cr it works, I get the numeric of 123, but when I send X Cr and then 123 Cr I only get the number 1 when calling get_num().
What am I missing?
long get_num()
long get_num_sum = 0;
int sign = 1;
char got_char;
while (!Serial.available() );
got_char = Serial.read();
// Serial.print("Got char 1 "); Serial.println(got_char);
if (got_char == '-' )
sign = -1;
get_num_sum = 0;
// Serial.print("Sum inside sign check - "); Serial.println(get_num_sum);
get_num_sum = long(got_char - '0');
while (Serial.available())
Serial.print("Got char n "); Serial.println(got_char); Serial.print("sum = "); Serial.println(get_num_sum);
// if (isAlphaNumeric(got_char)) sum = (sum * 10) + long(got_char - '0');
get_num_sum = (get_num_sum * 10) + long(got_char - '0');
Serial.print("Get_num reads "); Serial.println(get_num_sum * sign);
return (get_num_sum * sign);
char get_cmd()
return (Serial.read());
void figures()
char cmd, cmd_2;
long depth = 81;
int motor = motorX;
int nr_steps;
long step_delay2;
mylcd.clear();
mylcd.print("C Circle");
mylcd.setCursor(0, 1);
mylcd.print("H Hole");
mylcd.setCursor(0, 2);
mylcd.print("S Step motor");
mylcd.setCursor(0, 3);
mylcd.print("Z Set axle to zero");
// 01234567890123456789
cmd = get_cmd();
switch (cmd)
case 'C': Serial.print("Figure circle ended "); Serial.println(millis());
case 'c':
mylcd.clear();
mylcd.print("Circl Depth Rad Ang");
global_angle_print_flag = true;
global_depth_print_flag = true;
//void makecircle(float (angle_start), float (angle_stop), long(xcenter), long(ycenter), long(radius), float(astep))
digitalWrite( 8, LOW);//Enable motorpower
Serial.print("Figure circle started "); Serial.println(millis());
for (int i = 40; i < depth; i += 40)
goxyz(motorZ, zpos - 40, zwork_delay);
mylcd.setCursor(8, 1); mylcd.print(" "); mylcd.setCursor(8, 1); mylcd.print(zpos);
makecircle(0, 2 * pi, 4000, 4000, 800, 10.0 / 360.0 * pi); //2 degrees stepping angle
global_angle_print_flag = false;
global_depth_print_flag = false;
goxyz(motorZ, 0, ztransport_delay);
goxyz(motorX, 0, xtransport_delay);
goxyz(motorY, 0, ytransport_delay);
digitalWrite( 8, HIGH);//Disable motorpower
case 'H':
case 'h':
mylcd.clear();
mylcd.print("H Hole De Rad Ang");
global_radious_print_flag = true;
// makehole(float (angle_start), float (angle_stop), long(xcenter), long(ycenter), long(radius), float(astep))
Serial.print("Figure hole started "); Serial.println(millis());
makehole(0.0, 2 * pi, 4000, 4000, 1200, 10.0 * pi / 360.0); //1 degree stepping angle
global_radious_print_flag = false;
Serial.print("Figure hole ended "); Serial.println(millis());
case 'S'://Step motor
case 's':
mylcd.clear();
mylcd.print("Step motor ");
mylcd.setCursor(0, 1); mylcd.print("Motor. X, Y, Z ");
// global_radious_print_flag = true;
Serial.print("Stepping motor ");
cmd_2 = get_cmd();
switch (cmd_2)
case 'X':
case 'x':
motor = motorX;
step_delay2 = xtransport_delay;
mylcd.print("X");
Serial.println("X");
nr_steps = get_num();
mylcd.setCursor(0, 2); mylcd.print("Steps "); mylcd.print(nr_steps);
goxyz(motorX, xpos + nr_steps, xtransport_delay);
case 'Y':
case 'y':
motor = motorY;
step_delay2 = ytransport_delay;
mylcd.print("Y");
Serial.println("Y");
goxyz(motorY, ypos + nr_steps, ytransport_delay);
} // 01234567890123456789
case 'Z':
case 'z':
motor = motorZ;
step_delay2 = ztransport_delay;
mylcd.print("Z");
Serial.println("Z");
goxyz(motorZ, zpos + nr_steps, ztransport_delay);
}//End of case step motor
mylcd.clear();
pos_print(xpos, ypos, xpos);
mylcd.setCursor(0, 0); mylcd.print("Send a char to skip");
cmd = get_cmd();//In order yo leave set zero
// break;
}//End of switch step motor
case 'Z'://Set axle to zero
case 'z':
mylcd.clear();
cmd_2 = get_cmd();
switch (cmd_2)
case 'X':
case 'x':
xpos = 0;
case 'Y':
case 'y':
ypos = 0;
case 'Z':
case 'z':
zpos = 0;
}//End switch cmd set zero
mylcd.clear();
}//End of Zero axle stepping
mylcd.clear();
}//end of switch cmd
}//End of figures
