Hi There,
I am trying to use 2 softwareserial ports in a fucntion but cant seem to get it working. When I use the code outside of the function it works so I think I am maybe using incorrect data type or syntax. Can anyone tell me what I am doing wrong ? I am using 2 JSN-SR04T in serial mode and a Nano Every for a water tank level. I know softserial is not the best but I am only going to update data every 5 mins or so, so not concerned if the MCU is slowed down.
#include <SoftwareSerial.h>
// Define connections to sensor
int S1_RX = 9;
int S1_TX = 8;
int S2_RX = 11;
int S2_TX = 10;
// Array to store incoming serial data
unsigned char data_buffer[4] = {0};
// Variable to hold checksum
unsigned char CS;
// defines variables
long duration;
int distance;
int TankLevel1;
int TankLevel2;
String Tank1;
String Tank2;
String S1 = "% ";
String S2 = "L";
String Header1 = "Tank 1 Level: ";
String Header2 = "Tank 2 Level: ";
int TankR = 90; //Tank Radius in cm
int TankH = 204; //Tank Height in cm 23cm + 181 cm
int StringLength;
// Object to represent software serial port
SoftwareSerial Sensor1(S1_RX, S1_TX);
SoftwareSerial Sensor2(S2_RX, S2_TX);
// set the LCD address to 0x27 for a 16 chars and 2 line display
LiquidCrystal_I2C lcd(0x27, 16, 2);
//Level measurement Routine
int MeasureLevel (Stream &Sensor)
if (Sensor.available() > 0) {
delay(4);
// Check for packet header character 0xff
if (Sensor.read() == 0xff) {
// Insert header into array
data_buffer[0] = 0xff;
// Read remaining 3 characters of data and insert into array
for (int i = 1; i < 4; i++) {
data_buffer[i] = Sensor.read();
//Compute checksum
CS = data_buffer[0] + data_buffer[1] + data_buffer[2];
// If checksum is valid compose distance from data
if (data_buffer[3] == CS) {
distance = (data_buffer[1] << 8) + data_buffer[2];
Serial.println(String("Distance: ") + distance);
return distance;
void UpdateDisplay(int Length, String string1, String string2)
lcd.setCursor(0, 0);
lcd.print(string1);
lcd.setCursor(0, 1);
lcd.print(string2);
for (int positionCounter = 0; positionCounter < Length; positionCounter++) {
// scroll one position left:
lcd.scrollDisplayLeft();
// wait a bit:
// scroll one position right:
lcd.scrollDisplayRight(); \
// Set up software serial port
Sensor1.begin(9600);
Sensor2.begin(9600);
lcd.init();
lcd.clear();
lcd.backlight(); // Make sure backlight is on
// Determine Tank1 water level and calculate volume to display
TankLevel1 = MeasureLevel (Sensor1);
int x1 = TankH - (TankLevel1/100);
int v1 = constrain(((PI * (TankR * TankR) * x1) / 1000), 0, 4600); // Pi*r^2*height of water /1000000 to get m^3 then *1000 to get liters
int p1 = constrain((v1 * 100 / 4600), 0, 100); // Tank Fill percentage 4600 L is usable
Tank1 = Header1 + p1 + S1 + v1 + S2; //Build String for Display
// Determine Tank2 water level and calculate volume to display
TankLevel2 = MeasureLevel (Sensor2);
int x2 = TankH - (TankLevel2/100);
int v2 = constrain(((PI * (TankR * TankR) * x2) / 1000), 0, 4600); // Pi*r^2*height of water /1000000 to get m^3 then *1000 to get liters
int p2 = constrain((v2 * 100 / 4600), 0, 100); // Tank Fill percentage 4600 L is usable
Tank2 = Header2 + p2 + S1 + v2 + S2; //Build String for Display
StringLength = Tank1.length();
//debug
Serial.println(String("Tank 1 Level ") + TankLevel1 + String(" x1 ") + x1 + String(" v1 ") + v1 + String(" p1 ") + p1);
Serial.println(String("Tank 2 Level ") + TankLevel2 + String(" x2 ") + x2 + String(" v2 ") + v2 + String(" p2 ") + p2);
//Update Display
UpdateDisplay(StringLength / 2, Tank1, Tank2);
delay(1000); //Update data every 1s
