here is the .ino
// User selects a file from the SD card list and plays the music
// Example program to demonstrate the use of the MIDFile library
// Hardware required:
// SD card interface - change SD_SELECT for SPI comms
// LCD interface - assumed to be 2 rows 16 chars. Change LCD
// pin definitions for hardware setup
#include <SdFat.h>
#include <MIDIFile.h>
#include <LiquidCrystal.h>
#include "KeyPress.h" // handle analog keys on LCD shield
#include "types.h" // FSM enumerated types
#define DEBUG_MODE 0
#if DEBUG_MODE
#define DEBUG(x) Serial.print(x)
#define DEBUGX(x) Serial.print(x, HEX)
#define SERIAL_RATE 57600
#else
#define DEBUG(x)
#define DEBUGX(x)
#define SERIAL_RATE 31250
#endif
// SD Hardware defines ---------
// SPI select pin for SD card (SPI comms).
// Arduino Ethernet shield, pin 4.
// Default SD chip select is the SPI SS pin (10).
// Other hardware will be different as documented for that hardware.
#define SD_SELECT 10
// LCD display defines ---------
#define LCD_ROWS 2
#define LCD_COLS 16
// LCD user defined characters
#define PAUSE '\1'
uint8_t cPause[8] =
0b10010,
0b10010,
0b10010,
0b10010,
0b10010,
0b10010,
0b10010,
0b00000
// LCD pin definitions ---------
// These need to be modified for the LCD hardware setup
#define LCD_RS 8
#define LCD_ENA 9
#define LCD_D4 4
#define LCD_D5 (LCD_D4+1)
#define LCD_D6 (LCD_D4+2)
#define LCD_D7 (LCD_D4+3)
// Library objects -------------
LiquidCrystal LCD(LCD_RS, LCD_ENA, LCD_D4, LCD_D5, LCD_D6, LCD_D7);
SdFat SD;
MIDIFile SMF;
// Playlist handling -----------
#define FNAME_SIZE 13 // 8.3 + '\0' character file names
#define PLAYLIST_FILE "PLAYLIST.TXT" // file of file names
#define MIDI_EXT ".MID" // MIDI file extension
uint16_t plCount = 0;
// MIDI callback functions for MIDIFile library ---------------
void midiCallback(midi_event *pev)
// Called by the MIDIFile library when a file event needs to be processed
// thru the midi communications interface.
// This callback is set up in the setup() function.
#if !DEBUG_MODE
if ((pev->data[0] >= 0x80) && (pev->data[0] <= 0xe0))
Serial.write(pev->data[0] | pev->channel);
Serial.write(&pev->data[1], pev->size-1);
Serial.write(pev->data, pev->size);
#endif
DEBUG("\nM T");
DEBUG(pev->track);
DEBUG(": Ch ");
DEBUG(pev->channel+1);
DEBUG(" Data ");
for (uint8_t i=0; i<=pev->size; i++)
DEBUGX(pev->data[i]);
DEBUG(' ');
void sysexCallback(sysex_event *pev)
// Called by the MIDIFile library when a system Exclusive (sysex) file event needs
// to be processed thru the midi communications interface. MOst sysex events cannot
// really be processed, so we just ignore it here.
DEBUG("\nS T");
DEBUG(pev->track);
DEBUG(": Data ");
for (uint8_t i=0; i<pev->size; i++)
DEBUG(' ');
void midiSilence(void)
// Turn everything off on every channel.
// Some midi files are badly behaved and leave notes hanging, so between songs turn
// off all the notes and sound
midi_event ev;
// All sound off
// When All Sound Off is received all oscillators will turn off, and their volume
// envelopes are set to zero as soon as possible.
ev.size = 0;
ev.data[ev.size++] = 0xb0;
ev.data[ev.size++] = 120;
ev.data[ev.size++] = 0;
for (ev.channel = 0; ev.channel < 16; ev.channel++)
midiCallback(&ev);
// LCD Message Helper functions -----------------
void LCDMessage(uint8_t r, uint8_t c, const char *msg, bool clrEol = false)
// Display a message on the LCD screen with optional spaces padding the end
LCD.setCursor(c, r);
LCD.print(msg);
if (clrEol)
c += strlen(msg);
while (c++ < LCD_COLS)
LCD.write(' ');
void LCDErrMessage(const char *msg, bool fStop)
LCDMessage(1, 0, msg, true);
while (fStop) ; // stop here if told to
delay(2000); // if not stop, pause to show message
// Create list of files for menu --------------
uint16_t createPlaylistFile(void)
// create a playlist file on the SD card with the names of the files.
// This will then be used in the menu.
SdFile plFile; // Playlist file
SdFile mFile; // MIDI file
uint16_t count; // count of files
char fname[FNAME_SIZE];
// open/create the playlist file
if (!plFile.open(PLAYLIST_FILE, O_CREAT|O_WRITE))
LCDErrMessage("PL create fail", true);
count = 0;
while (mFile.openNext(SD.vwd(), O_READ))
if (mFile.isFile())
mFile.getFilename(fname);
if (strcmp(MIDI_EXT, &fname[strlen(fname)-strlen(MIDI_EXT)]) == 0)
// only include files with MIDI extenstion
plFile.write(fname, FNAME_SIZE);
count++;
mFile.close();
// close the playlist file
plFile.close();
return(count);
// FINITE STATE MACHINES -----------------------------
seq_state lcdFSM(seq_state curSS)
// Handle selecting a file name from the list (user input)
static lcd_state s = LSBegin;
static uint8_t plIndex = 0;
static char fname[FNAME_SIZE];
static SdFile plFile; // Playlist file
// LCD state machine
switch (s)
case LSBegin:
LCDMessage(0, 0, "Select music:", true);
if (!plFile.isOpen())
if (!plFile.open(PLAYLIST_FILE, O_READ))
LCDErrMessage("PL file no open", true);
s = LSShowFile;
case LSShowFile:
plFile.seekSet(FNAME_SIZE*plIndex);
plFile.read(fname, FNAME_SIZE);
LCDMessage(1, 0, fname, true);
LCD.setCursor(LCD_COLS-2, 1);
LCD.print(plIndex == 0 ? ' ' : '<');
LCD.print(plIndex == plCount-1 ? ' ' : '>');
s = LSSelect;
case LSSelect:
switch (getLCDKey())
// Keya are mapped as follows:
// Select: move on to the next state in the state machine
// Left: use the previous file name (move back one file name)
// Right: use the next file name (move forward one file name)
// Up: move to the first file name
// Down: move to the last file name
case 'S': // Select
s = LSGotFile;
case 'L': // Left
if (plIndex != 0)
plIndex--;
s = LSShowFile;
case 'U': // Up
plIndex = 0;
s = LSShowFile;
case 'D': // Down
plIndex = plCount-1;
s = LSShowFile;
case 'R': // Right
if (plIndex != plCount-1)
plIndex++;
s = LSShowFile;
case LSGotFile:
// copy the file name and switch mode to playing MIDI
SMF.setFilename(fname);
curSS = MIDISeq;
// fall through to default state
default:
s = LSBegin;
return(curSS);
seq_state midiFSM(seq_state curSS)
// Handle playing the selected MIDI file
static midi_state s = MSBegin;
switch (s)
case MSBegin:
// Set up the LCD
LCDMessage(0, 0, SMF.getFilename(), true);
LCDMessage(1, 0, "K \xdb \1 >", true); // string of user defined characters
s = MSLoad;
case MSLoad:
// Load the current file in preparation for playing
int err;
// Attempt to load the file
if ((err = SMF.load()) == -1)
s = MSProcess;
char aErr[16];
sprintf(aErr, "SMF error %03d", err);
LCDErrMessage(aErr, false);
s = MSClose;
case MSProcess:
// Play the MIDI file
if (!SMF.isEOF())
SMF.getNextEvent();
s = MSClose;
// check the keys
case 'S': SMF.restart(); break; // Rewind
case 'L': s = MSClose; break; // Stop
case 'U': SMF.pause(true); break; // Pause
case 'D': SMF.pause(false); break; // Start
case 'R': break; // Nothing assigned to this key
case MSClose:
// close the file and switch mode to user input
SMF.close();
midiSilence();
curSS = LCDSeq;
default:
s = MSBegin;
return(curSS);
void setup(void)
int err;
// initialise MIDI output stream
Serial.begin(SERIAL_RATE);
// initialise LCD display
LCD.begin(LCD_COLS, LCD_ROWS);
LCD.clear();
LCD.noCursor();
LCDMessage(0, 0, " Midi Player ", false);
LCDMessage(1, 0, " ------------ ", false);
// Load characters to the LCD
LCD.createChar(PAUSE, cPause);
pinMode(KEY_ADC_PORT, INPUT);
// initialise MIDIFile
SMF.begin(&SD);
SMF.setMidiHandler(midiCallback);
SMF.setSysexHandler(sysexCallback);
// initialise SDFat
if (!SD.begin(SD_SELECT, SPI_FULL_SPEED))
LCDErrMessage("SD init fail!", true);
plCount = createPlaylistFile();
if (plCount == 0)
LCDErrMessage("No files", true);
delay(750); // allow the welcome to be read on the LCD
void loop(void)
// only need to looak after 2 things - the user interface (LCD_FSM)
// and the MIDI playing (MIDI_FSM). While playuing we have a different
// mode from choosing the file, so the FSM will run alternately, depending
// on which state we are currently in.
static seq_state s = LCDSeq;
switch (s)
case LCDSeq: s = lcdFSM(s); break;
case MIDISeq: s = midiFSM(s); break;
default: s = LCDSeq;
