Trouble when connecting limit switch
Hi! I am trying to connect a limit switch but the output in my serial monitor does not make sense.
Wiring goes from Arduino UNO digital port 2 to limit switch, then from limit switch to 10k ohm resistor, then to Arduino ground.
When the limit switch is connected and I press it i get 0 repeatedly in the serial monitor, but when I release the button the serial monitor alternates between 0 and 1 at seemingly random intervals. Even when i disconnect the switch it still reads lots of 0s and 1s randomly. I would expect it to read either 0 or 1, not both. Is there something wrong with my arduino? Or am i doing something wrong? I have tried different cables, different switches (same brand/type) and different connector/pins.
Here is the code im using :
Kodeutsnittint BUTTON_PIN = 2;
int buttonState =0;
pinMode (BUTTON_PIN, INPUT);
buttonState = digitalRead(BUTTON_PIN);
Serial.println(buttonState);
}Kodeutsnitt
Floating Inputs and its Mitigating Measure in Arduino
Floating Inputs and its Mitigating Measure in Arduino.
Help us help you.
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
Please post a schematic.
Please post an image of your project.
Please describe the problem better then you just did.
Use
pinMode (BUTTON_PIN, INPUT_PULLUP);
Sorry, will do better on my next post
This fixed it, thanks!!
Your topic has been moved to a more suitable location on the forum. Introductory Tutorials is for tutorials that e.g. you write, not for questions. Feel free to write a tutorial once you have solved your problem :wink:
