Hello,
I'm trying to make a score board from three 7-segmend LED's that gets incremented from switches. I'm using a schematic that someone posted on here previously for it (attached). My problem is that all the segments stay lit, no matter what I change to the code. It was previously changing like it was supposed to before but now they all just display 8 (all segments on). I was wondering what could be wrong? or maybe some suggestions to trouble shoot.
Thanks
#include "LedControl.h"
#include <Servo.h>
Servo myservo;
LedControl lc=LedControl(12,11,10,1);
int n = 0 ;
int numberArray[2];
int buttonPin1 = 2;
int buttonPin2 = 3;
int buttonPin3 = 4;
int buttonPin4 = 5;
int buttonPin5 = 6;
int buttonState1 = 0;
int buttonState2 = 0;
int buttonState3 = 0;
int buttonState4 = 0;
int buttonState5 = 0;
int resetbutton = 8;
int resetstate = 0;
int count = 0;
//int a = 5;
myservo.attach(9);
lc.shutdown(0,false);
/* Set the brightness to a medium values */
lc.setIntensity(0,8);
/* and clear the display */
lc.clearDisplay(0);
/*lc.setDigit(0,1,(byte)0,false);
lc.setDigit(0,0,(byte)0,false);
lc.setDigit(0,2,(byte)0,false);
numberArray[0] = 0;
numberArray[1] = 0;
void loop() { while(1){
buttonState1 = digitalRead(buttonPin1);
buttonState2 = digitalRead(buttonPin2);
buttonState3 = digitalRead(buttonPin3);
buttonState4 = digitalRead(buttonPin4);
buttonState5 = digitalRead(buttonPin5);
resetstate= digitalRead(resetbutton);
if (count == 0) {
lc.setDigit(0,3,(byte)1,false);
lc.setDigit(0,4,(byte)0,false);
if (buttonState1 == HIGH) {
if (n == 9) {
numberArray[1]++;
n = 0;}
else {
n++;}
numberArray[0] = n;
count++;
delay(300);
if (buttonState2 == HIGH) {
if (n == 8) {
numberArray[1]++;
n = 0;}
else if (n == 9) {
numberArray[1]++;
n = 1; }
else {
n = n + 2;}
numberArray[0] = n;
count++;
delay(300);
if (buttonState3 == HIGH) {
if (n == 7) {
numberArray[1]++;
n = 0;}
else if (n == 8) {
numberArray[1]++;
n = 1; }
else if (n == 9) {
numberArray[1]++;
n = 2; }
else {
n = n + 3;}
numberArray[0] = n;
count++;
delay(300);
if (buttonState4 == HIGH) {
if (n == 6) {
numberArray[1]++;
n = 0;}
else if (n == 7) {
numberArray[1]++;
n = 1; }
else if (n == 8) {
numberArray[1]++;
n = 2; }
else if (n == 9) {
numberArray[1]++;
n = 3; }
else {
n = n + 4;}
numberArray[0] = n;
count++;
delay(300);
if (buttonState5 == HIGH) {
if (n == 5) {
numberArray[1]++;
n = 0;}
else if (n == 6) {
numberArray[1]++;
n = 1; }
else if (n == 7) {
numberArray[1]++;
n = 2; }
else if (n == 8) {
numberArray[1]++;
n = 3; }
else if (n == 9) {
numberArray[1]++;
n = 4; }
else {
n = n + 5;}
numberArray[0] = n;
count++;
delay(300);
if (count == 1){
lc.setDigit(0,3,(byte)0,false);
lc.setDigit(0,4,(byte)9,false);
else if (count == 2) {
lc.setDigit(0,4,(byte)8,false);
else if (count == 3) {
lc.setDigit(0,4,(byte)7,false);
else if (count == 4) {
lc.setDigit(0,4,(byte)6,false);
else if (count == 5) {
lc.setDigit(0,4,(byte)5,false);
else if (count == 6) {
lc.setDigit(0,4,(byte)4,false);
else if (count == 7) {
lc.setDigit(0,4,(byte)3,false);
else if (count == 8) {
lc.setDigit(0,4,(byte)2,false);
else if (count == 9) {
lc.setDigit(0,4,(byte)1,false);
else if(count == 10) {
if(count == 10) {
myservo.write(180);}
else{
myservo.write(0);
if (resetstate == LOW) {
count = 0;
numberArray[0] = 0;
numberArray[1] = 0;
numberArray[2] = 0;
n = 0;
lc.setDigit(0,1,(byte)numberArray[0],false);
lc.setDigit(0,0,(byte)numberArray[1],false);
Sorry for the lack of commenting, its based off a maxim7219 library example.
circuit.pdf (46.2 KB)
seven segment led.pdf (154 KB)
