Trouble with BMP280 sensor and SD Card logger
Hello all,
I am trying to set up and Uno to sense pressure and temp via the BMP280 board and then log it to an Adadfruit micro SD card breakout. I managed to get sensor working but when I try to incorporate code to log the data to the SD card I’m told that the ‘File does not name a type’ for the line ‘File mySensorData’ I thought I was identifying an object for the data to be written to with this command.
I have allocated the chip select pins as pin 9 to the BMP280 and pin 4 to the SD Card reader/writer.
I know the SD Card reader/writer works as I’ve tested that independantly with a test sketch.
I’m confident the wiring is accurate given both the sensor and the SD card have functioned usingother sketches.
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_BMP280.h>
#define BMP_SCK 13
#define BMP_MISO 12
#define BMP_MOSI 11
#define BMP_CS 9
//Adafruit_BMP280 bmp; // I2C
//Adafruit_BMP280 bmp(BMP_CS); // hardware SPI
Adafruit_BMP280 bmp(BMP_CS, BMP_MOSI, BMP_MISO, BMP_SCK);
int chipSelect = 4; //chipSelect pin for the SD card Reader
File mySensorData; //Data object you will write your sesnor data to
Serial.println(F(“BMP280 test”));
pinMode(10, OUTPUT); //Must declare 10 an output and reserve it
SD.begin(chipSelect); //Initialize the SD card reader
if (!bmp.begin()) {
Serial.println(F(“Could not find a valid BMP280 sensor, check wiring!”));
while (1);
mySensorData = SD.open(“PTData.txt”, FILE_WRITE);
if (mySensorData) {
Serial.print(F(“Temperature = “));
Serial.print(bmp.readTemperature());
Serial.println(” *C”);
Serial.print(F(“Pressure = “));
Serial.print(bmp.readPressure());
Serial.println(” Pa”);
Serial.print(F(“Approx altitude = “));
Serial.print(bmp.readAltitude(1013.25)); // this should be adjusted to your local forcase
Serial.println(” m”);
delay(250); //pause between readings
mySensorData.print(tempF); //write temperature data to card
mySensorData.print(","); //write a commma
mySensorData.println(pressure); //write pressure and end the line (println)
mySensorData.close(); //close the file
Any help you are able to give would be greatly appreciated, I am a total novice at this. The finished result will be going to the stratosphere under a weather balloon…hopefully!
Thank you in advance.
Best wishes
Phil
You may have met this problem: https://forum.arduino.cc/index.php?topic=360718.0
That's great, thanks for your help I will have a look at this.
Best wishes
Phil
Can your BMP be wires as I2C (TWI)? (solves the problem) Adafruits shield uses 4050 buffer..? MI-line cannot be rerouted.
