I am trying to build a data logger that will enter a new line in a TXT or a CSV file on a memory stick.
So I built a function inspired from the examples, "append".
void Append (char Write[])
printInfo("COMMAND2: Append data to file: " ); // Append data to the end of the file.
flashDrive.setFileName("MITCHFIL.TXT"); //set the file name
if(flashDrive.openFile() == ANSW_USB_INT_SUCCESS){ //open the file
flashDrive.moveCursor(CURSOREND); //if the file exist, move the "virtual" cursor at end of the file, with CURSORBEGIN we actually rewrite our old file
//flashDrive.moveCursor(flashDrive.getFileSize()); // is almost the same as CURSOREND, because we put our cursor at end of the file
if(flashDrive.getFreeSectors())
{ //check the free space on the drive
flashDrive.writeFile(Write, strlen(Write)); //string, string length
Serial.println (Write);
printInfo("Disk full");
flashDrive.closeFile(); //at the end, close the file
printInfo("Done!");
Weird things are happening next:
First of all, the file name does not end in TXT but in some weird character...MITCHFIL.TXÄ
Also, instead of appending a new line to the same file, I am creating a new file with the same name. The data inside the file is correct. But this is not what I need.
Here is the example from the library, it works fine.
case 50: //2
printInfo("COMMAND2: Append data to file: TEST1.TXT"); // Append data to the end of the file.
flashDrive.setFileName("TEST1.TXT"); //set the file name
for(int a = 0; a < 20; a++){ //write text from string(adat) to flash drive 20 times
if(flashDrive.getFreeSectors()){ //check the free space on the drive
flashDrive.writeFile(adat2, strlen(adat2)); //string, string length
Serial.println (adat2);
printInfo("Done!"
What am I doing wrong?
Thanks ,
Mitch
