Trouble with code
// RGB Light
int switchPin = 2;
int redPin = 5;
int greenPin = 6;
int bluePin = 3;
int val;
int val2;
int buttonState;
int lightMode = 0;
  pinMode(switchPin, INPUT);
  pinMode(redPin, OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(bluePin, OUTPUT);
  buttonState = digitalRead(switchPin);
void loop(){
  val = digitalRead(switchPin);
  delay(10);
  val2 = digitalRead(switchPin);
  if (val == val2) {
    if (val != buttonState) {
      if (val == LOW) {
        if (lightMode == 0) {
          lightMode = 1;
          if (lightMode == 1) {
            lightMode = 2;
            if (lightMode == 2) {
              lightMode = 3;
           if (lightMode == 3) {
             lightMode = 4;
            }   else {
                lightMode = 0;
    buttonState = val;
analogWrite(redPin, 0);
analogWrite(greenPin, 0);
analogWrite(bluePin, 0);
    analogWrite(redPin, 255);
    analogWrite(bluePin, 255);
    analogWrite(greenPin, 255);
  if (lightMode == 4) {
    analogWrite(redPin, 100);
    analogWrite(greenPin, 180);
    analogWrite(bluePin, 100);
    analogWrite(greenPin, 100);
    analogWrite(greenPin, 170);
    analogWrite(bluePin, 80);
Works fine till I press the button the 4th time to the delayed analogWrite.
I adapted from lady ada's code.
Works fine
Define "fine" (or the opposite)
Are you missing a "}" somewhere in there? (since lightMode can't be 3 and 4 simultaneously)
Things become clearer if you use the Auto Format tool:
int switchPin = 2;
int redPin = 5;
int greenPin = 6;
int bluePin = 3;
int val;
int val2;
int buttonState;
int lightMode = 0;
void loop(){
  delay(10);
  if (val == val2) {
      if (val == LOW) {
          lightMode = 1;
        else {
            lightMode = 2;
          else {
              lightMode = 3;
            else {
                lightMode = 4;
              else {
                lightMode = 0;
    buttonState = val;
Yes it uploads fine... Problem is when hits button 4 it wont physically do whats in the code...:
I was missing a }
:slight_smile:
