Hello,
I'm having difficulty developing a hmc5883l compass with Processing.
I followed a tutorial (ArduiKyo: HMC5883L Compass + Arduino + Processing) but I'm finding just the number 49 repeatedly in serial monitor. are not coordinated, just the number 49.
what could it be?
pedrorodrigo:
and if I use an example of HMC5883L, this happens:is a hardware problem??
Not if the magnetometer is lying still.
On the reason for the 49 on your first post, it's hard to tell. I am having trouble seeing your code. Some folks would assume that you correctly copied working code to your Arduino, but those folks are not me. Call me skeptical.
On the reason for the 49 on your first post, it’s hard to tell. I am having trouble seeing your code. Some folks would assume that you correctly copied working code to your Arduino, but those folks are not me. Call me skeptical.
[/quote]
Hahaha I’m glad to hear that.
here’s the example of the manufacturer’s own library:
// Reference the I2C Library
#include <Wire.h>
// Reference the HMC5883L Compass Library
#include <HMC5883L.h>
// Store our compass as an object.
HMC5883L compass;
// Record any errors that may occur in the compass.
int error = 0;
// Out setup routine, here we will configure the microcontroller and compass.
// Initialize the serial port.
Serial.println("Starting the I2C interface.");
Wire.begin(); // Start the I2C interface.
Serial.println("Constructing new HMC5883L");
compass = HMC5883L(); // Construct a new HMC5883 compass.
//The implementation of the class is provided in the library
// Now we have an istance of the class!
//Let's initializate it...
Serial.println("Setting scale to +/- 1.3 Ga");
error = compass.SetScale(1.3); // Set the scale of the compass to 1.3Ga
if(error != 0){ // If there is an error, print it out.
Serial.println(compass.GetErrorText(error));
error =0;
Serial.println("Setting measurement mode to continous.");
error = compass.SetMeasurementMode(Measurement_Continuous); // Set the measurement mode to Continuous
if(error != 0) {// If there is an error, print it out.
Serial.println(compass.GetErrorText(error)); //Todo: Error handling for this method in .h and .cpp
error=0;
// Our main program loop.
// Retrieve the raw values from the magnetometer (not scaled).
MagnetometerRaw raw = compass.ReadRawAxis();
// Retrieve the scaled values from the magnetometer (scaled to the configured scale).
MagnetometerScaled scaled = compass.ReadScaledAxis();
// Values are accessed like so:
int MilliGauss_OnThe_XAxis = scaled.XAxis;// (or YAxis, or ZAxis)
// Calculate heading when the magnetometer is level, then correct for signs of axis.
// Atan2() automatically check the correct formula taking care of the quadrant you are in
float heading = atan2(scaled.YAxis, scaled.XAxis);
// Once you have your heading, you must then add your 'Declination Angle',
// which is the 'Error' of the magnetic field in your location. Mine is 0.0404
// Find yours here: http://www.magnetic-declination.com/
// If you cannot find your Declination, comment out these two lines, your compass will be slightly off.
float declinationAngle = 0.0404;
heading += declinationAngle;
// Correct for when signs are reversed.
if(heading < 0)
heading += 2*PI;
// Check for wrap due to addition of declination.
if(heading > 2*PI)
heading -= 2*PI;
// Convert radians to degrees for readability.
float headingDegrees = heading * 180/M_PI;
// Output the data via the serial port.
Output(raw, scaled, heading, headingDegrees);
// By default the HMC5883L reads the data 15 time per second (15Hz)
// However since we have a long serial out (104ms at 9600) we will let
// it run at its natural speed.
// delay(66);
// Output the data down the serial port.
void Output(MagnetometerRaw raw, MagnetometerScaled scaled, float heading, float headingDegrees)
Serial.print("Raw:\t");
Serial.print(raw.XAxis);
Serial.print(" ");
Serial.print(raw.YAxis);
Serial.print(" ");
Serial.print(raw.ZAxis);
Serial.print(" \tScaled:\t");
Serial.print(scaled.XAxis);
Serial.print(" ");
Serial.print(scaled.YAxis);
Serial.print(" ");
Serial.print(scaled.ZAxis);
Serial.print(" \tHeading:\t");
Serial.print(heading);
Serial.print(" Radians \t");
Serial.print(headingDegrees);
Serial.println(" Degrees \t");
I used another simple tutorial to understand the problem, but the result was similar.
Repeated showed coordinates: X = -1, Y = -1 = Z -1.
link of the tutorial: http://fusion94.org/blog/2012/11/29/arduino-plus-compass-module-3-axis-hmc5883l/
A lot of folks seem to have problems with that manufacturer's library. I have seen several implementations without the library as well.
I don't have one of those devices, so I can't really help you further, except to say that you did find a sketch that seemed to work, so I would recommend using that one as a basis for your implementaion.
As well, if you Google "HMC5883L library arduino" (but without the quotes), you will find many threads here and elsewhere. They would be worth reading.
Please check this
