Trouble with connecting Ethernet shield to internet!
Hi!
Me and my friends are trying to connect the out Arduino Uno + Ethernet Shield.
We have tried the example programs "Chatserver" and "Webclient". None of these work.
Below is the we have tried, the ip address is one that i have been given and is free, but i cant even reach is when pinging.
When i use the serial monitor i says "Chat server address: 0.0.0.0", Why is it like this? Have anyone of you seen this problem before, and solved it?
The code i've for chat server is the one below.
Thanks for any help!
Chat Server
A simple server that distributes any incoming messages to all
connected clients. To use telnet to your device's IP address and type.
You can see the client's input in the serial monitor as well.
Using an Arduino Wiznet Ethernet shield.
Circuit:
  • Ethernet shield attached to pins 10, 11, 12, 13
  • Analog inputs attached to pins A0 through A5 (optional)
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network.
// gateway and subnet are optional:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEE, 0xFF, 0xDD
IPAddress ip(193, 10, 39, 160);
IPAddress gateway(193, 10, 39, 1);
IPAddress subnet(255, 255, 255, 0);
// telnet defaults to port 23
EthernetServer server(23);
boolean alreadyConnected = false; // whether or not the client was connected previously
// initialize the ethernet device
Ethernet.begin(mac, ip, gateway, subnet);
// start listening for clients
server.begin();
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.print("Chat server address:");
Serial.println(Ethernet.localIP());
// wait for a new client:
// when the client sends the first byte, say hello:
if (client) {
if (!alreadyConnected) {
// clead out the input buffer:
client.flush();
Serial.println("We have a new client");
client.println("Hello, client!");
alreadyConnected = true;
if (client.available() > 0) {
// read the bytes incoming from the client:
char thisChar = client.read();
// echo the bytes back to the client:
server.write(thisChar);
// echo the bytes to the server as well:
Serial.write(thisChar);
Try changing "Ethernet.begin(mac, ip, gateway, subnet);" to "Ethernet.begin(mac);".
This will allow the chat server to get an IP address through DHCP. To use a fixed address you have to add a DNS Server address and include that in Ethernet.begin():
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
IPAddress ip(192, 168, 1, 177);
IPAddress gateway(192, 168, 1, 1);
IPAddress dnsserver(192, 168, 1, 1);   //  If you leave this out the subnet mask gets used as the gateway address and fails
IPAddress subnet(255, 255, 0, 0);
  Ethernet.begin(mac, ip, dnsserver, gateway, subnet);  // Needs FIVE arguments if you want to specify subnet.
  server.begin();
This is not a good sign. It means the Arduino is not communicating with the shield on the SPI bus. Insure the shield is seated correctly and completely into the Arduino, especially the ICSP pins.
