Trouble with DateTime Library
This is my first post on this forum so I hope everything is correct, if it's not, I apologize.
I'm creating an automated gardening system based on this great instructable found here:http://www.instructables.com/id/Garduino-Gardening-Arduino/?ALLSTEPS
When I try to compile the code for the whole system I get this error:
Arduino: 1.5.4 (Mac OS X), Board: "Arduino Uno"
sketch_aug26b.ino: In function 'void setup()':
sketch_aug26b:45: error: 'DateTime' was not declared in this scope
sketch_aug26b.ino: In function 'void loop()':
sketch_aug26b:94: error: 'DateTime' was not declared in this scope
After doing a little research I thought maybe the problem had to do with the installation of the datetime library.
I checked that it was definitely installed, and it was present (on my mac) under sketch>import library, all the way at the bottom of the list
I then tried running the example code that came with the library and got this error:
DateTime.pde: In function 'void loop()':
DateTime:19: error: 'DateTime' was not declared in this scope
DateTime:21: error: 'DateTime' was not declared in this scope
DateTime:30: error: 'BYTE' was not declared in this scope
As of Arduino 1.0, the 'BYTE' keyword is no longer supported.
Please use Serial.write() instead.
DateTime.pde: In function 'boolean getPCtime()':
DateTime:41: error: 'time_t' was not declared in this scope
DateTime:41: error: expected `;' before 'pctime'
DateTime:45: error: 'pctime' was not declared in this scope
DateTime:48: error: 'DateTime' was not declared in this scope
DateTime:48: error: 'pctime' was not declared in this scope
DateTime.pde: In function 'void digitalClockDisplay()':
DateTime:57: error: 'DateTime' was not declared in this scope
DateTime:61: error: 'DateTimeStrings' was not declared in this scope
I've tried searching for a solution on my own but I'm at a total loss. Any help would be appreciated
Please do us and yourself a favour by posting the program copied from your IDE. When doing so please note the advice in the stickies at the top of this forum, particularly the advice to use code tags.
Well the compiler isn't finding the library by the look of it. You
haven't said which DateTime library nor posted your code though, so its guesswork
for now.
I'm a novice right now and didn't know that there was more than one DateTime library, the one I downloaded I found here:Arduino Playground - HomePage
As for the code, the example sketch code is:
// DateTime.pde
// example sketch for the DateTime library
#include <DateTime.h>
#include <DateTimeStrings.h>
#define TIME_MSG_LEN  11   // time sync to PC is HEADER followed by unix time_t as ten ascii digits
#define TIME_HEADER  255   // Header tag for serial time sync message
void setup(){
  Serial.begin(19200);
  pinMode(13,OUTPUT); // we flash the LED each second
void  loop(){
  unsigned long  prevtime;
  if( getPCtime()) {  // try to get time sync from pc
    Serial.print("Clock synced at: ");
    Serial.println(DateTime.now(),DEC);
  if(DateTime.available()) { // update clocks if time has been synced
    digitalWrite(13,LOW);  // first flash the LED
    prevtime = DateTime.now();
    while( prevtime == DateTime.now() )  // wait for the second to rollover
    DateTime.available(); //refresh the Date and time properties
    digitalClockDisplay( );   // update digital clock
    // send our time to any app at the other end of the serial port
    Serial.print( TIME_HEADER,BYTE); // this is the header for the current time
    Serial.println(DateTime.now());
    digitalWrite(13,HIGH);
  delay(100);
boolean getPCtime() {
  // if time sync available from serial port, update time and return true
  while(Serial.available() >=  TIME_MSG_LEN ){  // time message consists of a header and ten ascii digits
    if( Serial.read() == TIME_HEADER ) {
      time_t pctime = 0;
      for(int i=0; i < TIME_MSG_LEN -1; i++){
        char c= Serial.read();
        if( c >= '0' && c <= '9'){
          pctime = (10 * pctime) + (c - '0') ; // convert digits to a number
      DateTime.sync(pctime);   // Sync Arduino clock to the time received on the serial port
      return true;   // return true if time message received on the serial port
  return false;  //if no message return false
void digitalClockDisplay(){
  // digital clock display of current date and time
  Serial.print(DateTime.Hour,DEC);
  printDigits(DateTime.Minute);
  printDigits(DateTime.Second);
  Serial.print(" ");
  Serial.print(DateTimeStrings.dayStr(DateTime.DayofWeek));
  Serial.print(" ");
  Serial.print(DateTimeStrings.monthStr(DateTime.Month));
  Serial.print(" ");
  Serial.println(DateTime.Day,DEC);
void printDigits(byte digits){
  // utility function for digital clock display: prints preceding colon and leading 0
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits,DEC);
I hope this sheds a little more light on the problem for those more knowledgable than me. Also, I hope I posted more correctly this time. Again, any help is appreciated
Again I'm new to this, so how would one go about helping the compiler find the library?
Put it in sketchbook/libraries/DateTime/DateTime.h and
sketchbook/libraries/DateTime/DateTime.cpp and restart Arduino IDO
I have a mac and the sketchbook folder doesnt show up in my finder. I tried manually placing the .zip file in the library folder and still got the same error. Does anybody know where I could place the file on my mac to help the compiler find the library?
It is NOT repeat NOT an error in the libs installation, if it where that would have given a file not found error for the .h files.
It is just that the "DateTime" has not been declared.
Mark
Okay, so how would I go about declaring it? The code I listed was an example code so I assumed it to be correct.
Post the datetime lib header file but you have lost a line that read something like
DateTime; where type can be found from the header file.
Mark
I apologize for how new I am at this, this is one of my first projects. When I stick that at the beginning of the code, it still won't compile. Could you explain to me exactly where I should put it?
Scout123 I'm having similar problems:
when you have DateTime.h installed in the correct library location what is the date of the .h & .cpp files? mine are 18/09/2008 so I'm thinking we may be using old libraries.
When you try to compile do you get as error as follows:
The 'BYTE' keyword is no longer supported
which relates to the line of code as follows:
Love to know how to overcome this.
Regards all
