hi guys, I am using Arduino UNO and I am having same kind of trouble with all of my pins. But I will post what I am getting at pin 7. This is the code I am running. void setup() { Serial.begin(9600); pinMode(7, INPUT);
} void loop() { int sensorValue = digitalRead(7); Serial.print(sensorValue); delay(1000); }
... and this is what I am reading in my serial monitor. 110000000111100000010111000000111110000110000000001111110000001110.
I inserted one end of hookup wire in pin 7 and the other end is just left hanging, there is no connection. According to the references, When a pin is configured as an INPUT with pinMode, and read with digitalRead, the microcontroller will report HIGH if a voltage of 3 volts or more is present at the pin. There is no way the wire I inserted is sending 3 volts to pin 7. Basically there shouldn't be any 1's being displayed at the serial monitor. Once I remove the wire from pin 7 things go back to normal and I read only 0's at the serial monitor. I have also tried using digitalWrite(7,LOW); under pinMode(); with same results. I am attempting to interface the Arduino with a weighing scale in the long run. I need the pins to react to the voltages coming out of the scale's pins that are directly connecting to the LCD. So I don't want to set the pins to output or set the pinMode to HIGH. The wire I am using is a 22-guage, stranded hookup wire Rated 300V, 80 deg C, from RadioShack. Is there any compatibility issues with the wire I am using? is there something wrong with pins in my Arduino? or most likely I am missing something obvious. If anyone can point me in the right direction I will be eternally grateful. This has been pretty frustrating. Please help. =( =(
