I am having trouble with getting the ds3231 to return time in the 12hour format. I am using arduino Uno in the IDE 1.6. I am using the Eric Ayars library. I started by using his example “ds3231 set” sketch. I changed this part of the code> Clock.setClockMode(false);< to this > Clock.setClockMode(true);< and from what I think I understand is this is supposed to set the clock mode in 12 hour format.
DS3231_set.pde
Eric Ayars
4/11
Test of set-time routines for a DS3231 RTC
#include <DS3231.h>
#include <Wire.h>
DS3231 Clock;
byte Year;
byte Month;
byte Date;
byte DoW;
byte Hour;
byte Minute;
byte Second;
void GetDateStuff(byte& Year, byte& Month, byte& Day, byte& DoW,
byte& Hour, byte& Minute, byte& Second) {
// Call this if you notice something coming in on
// the serial port. The stuff coming in should be in
// the order YYMMDDwHHMMSS, with an 'x' at the end.
boolean GotString = false;
char InChar;
byte Temp1, Temp2;
char InString[20];
byte j=0;
while (!GotString) {
if (Serial.available()) {
InChar = Serial.read();
InString[j] = InChar;
j += 1;
if (InChar == 'x') {
GotString = true;
Serial.println(InString);
// Read Year first
Temp1 = (byte)InString[0] -48;
Temp2 = (byte)InString[1] -48;
Year = Temp1*10 + Temp2;
// now month
Temp1 = (byte)InString[2] -48;
Temp2 = (byte)InString[3] -48;
Month = Temp1*10 + Temp2;
// now date
Temp1 = (byte)InString[4] -48;
Temp2 = (byte)InString[5] -48;
Day = Temp1*10 + Temp2;
// now Day of Week
DoW = (byte)InString[6] - 48;
// now Hour
Temp1 = (byte)InString[7] -48;
Temp2 = (byte)InString[8] -48;
Hour = Temp1*10 + Temp2;
// now Minute
Temp1 = (byte)InString[9] -48;
Temp2 = (byte)InString[10] -48;
Minute = Temp1*10 + Temp2;
// now Second
Temp1 = (byte)InString[11] -48;
Temp2 = (byte)InString[12] -48;
Second = Temp1*10 + Temp2;
// Start the serial port
// Start the I2C interface
Wire.begin();
// If something is coming in on the serial line, it's
// a time correction so set the clock accordingly.
GetDateStuff(Year, Month, Date, DoW, Hour, Minute, Second);
//setClockMode(false); // set to 24h
//setClockMode(true); // set to 12h
Clock.setYear(Year);
Clock.setMonth(Month);
Clock.setDate(Date);
Clock.setDoW(DoW);
Clock.setHour(Hour);
Clock.setMinute(Minute);
Clock.setSecond(Second);
// Test of alarm functions
// set A1 to one minute past the time we just set the clock
// on current day of week.
//Clock.setA1Time(DoW, Hour, Minute+1, Second, 0x0, true,
//false, false);
// set A2 to two minutes past, on current day of month.
//Clock.setA2Time(Date, Hour, Minute+2, 0x0, false, false,
//false);
// Turn off both alarms
Clock.turnOffAlarm(1);
Clock.turnOffAlarm(2);
I formated the date and time in the serial monitor followed by the x. So yes I set the time which also allowed the code to jump into the if statement that contains the 12/24hr formater.
Then I used his next example DS3231_test.
DS3231_test.pde
Eric Ayars
4/11
Test/demo of read routines for a DS3231 RTC.
Turn on the serial monitor after loading this to check if things are
working as they should.
#include <DS3231.h>
#include <Wire.h>
DS3231 Clock;
bool Century=false;
bool h12;
bool PM;
byte ADay, AHour, AMinute, ASecond, ABits;
bool ADy, A12h, Apm;
Wire.begin();
// Start the serial interface
// send what's going on to the serial monitor.
// Start with the year
Serial.print("2");
if (Century) { // Won't need this for 89 years.
Serial.print("1");
Serial.print("0");
Serial.print(Clock.getYear(), DEC);
Serial.print(' ');
// then the month
Serial.print(Clock.getMonth(Century), DEC);
Serial.print(' ');
// then the date
Serial.print(Clock.getDate(), DEC);
Serial.print(' ');
// and the day of the week
Serial.print(Clock.getDoW(), DEC);
Serial.print(' ');
// Finally the hour, minute, and second
Serial.print(Clock.getHour(h12, PM), DEC);
Serial.print(' ');
Serial.print(Clock.getMinute(), DEC);
Serial.print(' ');
Serial.print(Clock.getSecond(), DEC);
// Add AM/PM indicator
if (h12) {
if (PM) {
Serial.print(" PM ");
Serial.print(" AM ");
Serial.print(" 24h ");
// Display the temperature
Serial.print("T=");
Serial.print(Clock.getTemperature(), 2);
// Tell whether the time is (likely to be) valid
if (Clock.oscillatorCheck()) {
Serial.print(" O+");
Serial.print(" O-");
// Indicate whether an alarm went off
if (Clock.checkIfAlarm(1)) {
Serial.print(" A1!");
if (Clock.checkIfAlarm(2)) {
Serial.print(" A2!");
// New line on display
Serial.print('\n');
// Display Alarm 1 information
Serial.print("Alarm 1: ");
Clock.getA1Time(ADay, AHour, AMinute, ASecond, ABits, ADy, A12h, Apm);
Serial.print(ADay, DEC);
if (ADy) {
Serial.print(" DoW");
Serial.print(" Date");
Serial.print(' ');
Serial.print(AHour, DEC);
Serial.print(' ');
Serial.print(AMinute, DEC);
Serial.print(' ');
Serial.print(ASecond, DEC);
Serial.print(' ');
if (A12h) {
if (Apm) {
Serial.print('pm ');
Serial.print('am ');
if (Clock.checkAlarmEnabled(1)) {
Serial.print("enabled");
Serial.print('\n');
// Display Alarm 2 information
Serial.print("Alarm 2: ");
Clock.getA2Time(ADay, AHour, AMinute, ABits, ADy, A12h, Apm);
if (ADy) {
Serial.print(' ');
Serial.print(' ');
Serial.print(' ');
if (A12h) {
if (Apm) {
Serial.print('pm');
Serial.print('am');
if (Clock.checkAlarmEnabled(2)) {
/* display alarm bits
Serial.print('\n');
Serial.print('Alarm bits: ');
Serial.print(ABits, DEC);
Serial.print('\n');
Serial.print('\n');
I get the following result. On the serial monitor.
2015 3 23 1 6 13 26 24h T=24.25 0+
Alarm 1: 7 DoW 2 0 11
Alarm 2: 12 DoW 4 4
The 24h tells me that the ds3231 is still in 24hr format.
The clock is very accurate and is counting but not in the 12 hour format.
What code do I need to modify to change this to 12hr format?
Any help would be appreciated. Thanks in advance.
