Trouble with Ethernet Shield
I’ve established a connection between my computer and an Arduino Mega 2560 with an Ethernet Shield, and I’m sending string via UDP. But, it appears to take a lot of time to establish the connection, and therefore the first string I receive is a large string consisting of seven strings I would want to receive one at a time.
“BLARGHHelloHelloHelloHelloHelloHello”
I can solve this by having a delay(30000), but I would like to find another way of doing it. Preferably reduce or eliminate the connection time.
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
//Arduino
IPAddress ip(192,168,3,177);
IPAddress gateway(192,168,3,1);
IPAddress subnet(255,255,255,0);
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0E, 0xC0, 0x28 };
unsigned int localPort = 8888;
//End Arduino
//Receiver
IPAddress receiver(192,168,3,208);
unsigned int receivePort = 11000;
//End Receiver
EthernetUDP udp;
  Ethernet.begin(mac,ip,gateway,gateway,subnet);
  udp.begin(localPort);
  //delay(30000);
  sendData("BLARGH");
  delay(2000);
  sendData("Hello");
void sendData(char* dataString)
  udp.beginPacket(receiver,receivePort);
  udp.write(dataString);
  udp.endPacket();
  delay(2000);
Can you do something like:
while( udp.begin(localPort) == 0 ) {
   // waiting message, dot etc. to serial console
instead of the delay ?
That resulted in it never sending anything over ethernet.
"BLARGHHelloHelloHelloHelloHelloHello"
The usual solution is for YOU to include delimiters, so the receiver knows where YOU think the stream of data starts and ends.
Yes, but I want to solve the problem, not go around it.
