Hey, working on a pitch-reactive led strip project, and I'm using an Arduino Pro Micro.
I'm using an FFT sketch from this tutorial. The specific sketch I'm using is the last one:
//generalized wave freq detection with 38.5kHz sampling rate and interrupts
//by Amanda Ghassaei
//http://www.instructables.com/id/Arduino-Frequency-Detection/
//Sept 2012
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 3 of the License, or
* (at your option) any later version.
//clipping indicator variables
boolean clipping = 0;
//data storage variables
byte newData = 0;
byte prevData = 0;
unsigned int time = 0;//keeps time and sends vales to store in timer[] occasionally
int timer[10];//sstorage for timing of events
int slope[10];//storage for slope of events
unsigned int totalTimer;//used to calculate period
unsigned int period;//storage for period of wave
byte index = 0;//current storage index
float frequency;//storage for frequency calculations
int maxSlope = 0;//used to calculate max slope as trigger point
int newSlope;//storage for incoming slope data
//variables for decided whether you have a match
byte noMatch = 0;//counts how many non-matches you've received to reset variables if it's been too long
byte slopeTol = 3;//slope tolerance- adjust this if you need
int timerTol = 10;//timer tolerance- adjust this if you need
//variables for amp detection
unsigned int ampTimer = 0;
byte maxAmp = 0;
byte checkMaxAmp;
byte ampThreshold = 30;//raise if you have a very noisy signal
void setup(){
pinMode(13,OUTPUT);//led indicator pin
pinMode(12,OUTPUT);//output pin
cli();//diable interrupts
//set up continuous sampling of analog pin 0 at 38.5kHz
//clear ADCSRA and ADCSRB registers
ADCSRA = 0;
ADCSRB = 0;
ADMUX |= (1 << REFS0); //set reference voltage
ADMUX |= (1 << ADLAR); //left align the ADC value- so we can read highest 8 bits from ADCH register only
ADCSRA |= (1 << ADPS2) | (1 << ADPS0); //set ADC clock with 32 prescaler- 16mHz/32=500kHz
ADCSRA |= (1 << ADATE); //enabble auto trigger
ADCSRA |= (1 << ADIE); //enable interrupts when measurement complete
ADCSRA |= (1 << ADEN); //enable ADC
ADCSRA |= (1 << ADSC); //start ADC measurements
sei();//enable interrupts
ISR(ADC_vect) {//when new ADC value ready
PORTB &= B11101111;//set pin 12 low
prevData = newData;//store previous value
newData = ADCH;//get value from A0
if (prevData < 127 && newData >=127){//if increasing and crossing midpoint
newSlope = newData - prevData;//calculate slope
if (abs(newSlope-maxSlope)<slopeTol){//if slopes are ==
//record new data and reset time
slope[index] = newSlope;
timer[index] = time;
time = 0;
if (index == 0){//new max slope just reset
PORTB |= B00010000;//set pin 12 high
noMatch = 0;
index++;//increment index
else if (abs(timer[0]-timer[index])<timerTol && abs(slope[0]-newSlope)<slopeTol){//if timer duration and slopes match
//sum timer values
totalTimer = 0;
for (byte i=0;i<index;i++){
totalTimer+=timer[i];
period = totalTimer;//set period
//reset new zero index values to compare with
timer[0] = timer[index];
slope[0] = slope[index];
index = 1;//set index to 1
noMatch = 0;
else{//crossing midpoint but not match
if (index > 9){
reset();
else if (newSlope>maxSlope){//if new slope is much larger than max slope
maxSlope = newSlope;
time = 0;//reset clock
noMatch = 0;
index = 0;//reset index
else{//slope not steep enough
noMatch++;//increment no match counter
if (noMatch>9){
reset();
if (newData == 0 || newData == 1023){//if clipping
PORTB |= B00100000;//set pin 13 high- turn on clipping indicator led
clipping = 1;//currently clipping
time++;//increment timer at rate of 38.5kHz
ampTimer++;//increment amplitude timer
if (abs(127-ADCH)>maxAmp){
maxAmp = abs(127-ADCH);
if (ampTimer==1000){
ampTimer = 0;
checkMaxAmp = maxAmp;
maxAmp = 0;
void reset(){//clea out some variables
noMatch = 0;//reset match couner
maxSlope = 0;//reset slope
void checkClipping(){//manage clipping indicator LED
if (clipping){//if currently clipping
PORTB &= B11011111;//turn off clipping indicator led
clipping = 0;
void loop(){
checkClipping();
if (checkMaxAmp>ampThreshold){
frequency = 38462/float(period);//calculate frequency timer rate/period
//print results
Serial.print(frequency);
Serial.println(" hz");
delay(100);//delete this if you want
//do other stuff here
This code works perfectly on the Uno. On the pro micro, no matter which analog pin I plug the microphone into, the sketch doesn't pick it up.
I'm still getting into understanding microcontrollers. From what I can tell, this sketch uses the ADCH to specify A0, but I feel it's more complicated than that. I know direct port manipulation is required for in order to sample as fast as possible, but I can't figure out how to do it. Can anyone help me understand why it won't work on the micro?
Thanks
