I have instructed the config file to use the Modvk5121_Manual_Config.h file and triple checked my connections but I still get this when running GLCDdiags:
Serial initialized
GLCD Lib Configuration: glcd ver: 3 glcd_Device ver: 1 gText ver: 1
Panel Configuration:vk5121-Manual
Pin Configuration:vk5121-Manual
GLCD:sed1520 DisplayWidth:120 DisplayHeight:32
Chips:2 ChipWidth:60 ChipHeight:32
RW:14(PIN_C0) DI:16(PIN_C2) E1:15(PIN_C1) E2:17(PIN_C3)
D0:8(PIN_B0) D1:9(PIN_B1) D2:10(PIN_B2) D3:11(PIN_B3)
D4:4(PIN_D4) D5:5(PIN_D5) D6:6(PIN_D6) D7:7(PIN_D7)
Delays: tDDR:90 tAS:20 tDSW:80 tWH:100 tWL:80
Data mode:
d0-d3:nibble mode-Non-Atomic
d4-d7:nibble mode-Non-Atomic
Diag Loop: 1
Initializing GLCD
Displaying ChipSelect Screens
Walking 1s data test
Compare error: 0 != 40
TEST FAILED
One thing I did do was alter the timing parameters to this per the VK5121 datasheet:
// defines for panel specific timing
#define GLCD_tDDR 90 /* tACC6: Data Delay time (E high to valid read data) */
#define GLCD_tAS 20 /* tAW6: Address setup time (ctrl line changes to E high) */
#define GLCD_tDSW 80 /* tDS6: Data setup time (Write data lines setup to dropping E) */
#define GLCD_tWH 100 /* tEW: E hi level width (minimum E hi pulse width) */
#define GLCD_tWL 80 /* E lo level width (minimum E lo pulse width) */
// Original
//#define GLCD_tDDR 290 /* tACC6: Data Delay time (E high to valid read data) */
//#define GLCD_tAS 20 /* tAW6: Address setup time (ctrl line changes to E high) */
//#define GLCD_tDSW 200 /* tDS6: Data setup time (Write data lines setup to dropping E) *///
//#define GLCD_tWH 450 /* tEW: E hi level width (minimum E hi pulse width) */
//#define GLCD_tWL 450 /* E lo level width (minimum E lo pulse width) */
Both ways it didnt work. What should I look at first to track this error down?
Thanks
Greg
