trouble with GPS shield
i am using the adafruit GPS shield and when i tried download any gps code to the dem.. 168 arduino board i get this warning Binary sketch size =6462 avrdude:stk500_getsync(): not in sync:resp=0x00 avrdure:stk500_disable():protocol error ,expect=0x14,resp=0x51 I am new to arduino so pls. help also I ran the LCD display program and it worked fine
Try going to Tools > Board > Arduino w/ Atmega328
I did change to arduino with 328 in the tools and i still see the same error
Do you have it wired through pins 1 and 2? If so, you need to remove the TX jumper. Can you upload without the shield?
no i wdo not have the shield even connected. I try to download the program and connect the shield later. I just want to make sure the program downloads fine
Have you tried loading any other code onto the arduino?
i have downloaded LCD code and it works fine
