Trying to use the basic Graph setup from the examples library.
I'm getting the following error in Processing:
WARNING: RXTX Version mismatch
Jar version = RXTX-2.2pre1
native lib Version = RXTX-2.2pre2
[0] "/dev/tty.modem"
[1] "/dev/cu.modem"
[2] "/dev/tty.usbserial-A700eXmJ"
[3] "/dev/cu.usbserial-A700eXmJ"
dyld: lazy symbol binding failed: Symbol not found: _open$UNIX2003
Referenced from: /Applications/Processing 2.app/Contents/Resources/Java/modes/java/libraries/serial/library/macosx/librxtxSerial.jnilib
Expected in: /usr/lib/libSystem.B.dylibdyld: Symbol not found: _open$UNIX2003
Here's my code in Processing:
// Processing code for this example
// Graphing sketch
// This program takes ASCII-encoded strings
// from the serial port at 9600 baud and graphs them. It expects values in the
// range 0 to 1023, followed by a newline, or newline and carriage return
// Created 20 Apr 2005
// Updated 18 Jan 2008
// by Tom Igoe
// This example code is in the public domain.
import processing.serial.*;
Serial myPort; // The serial port
int xPos = 1; // horizontal position of the graph
void setup () {
// set the window size:
size(400, 300);
// List all the available serial ports
println(Serial.list());
// I know that the first port in the serial list on my mac
// is always my Arduino, so I open Serial.list()[0].
// Open whatever port is the one you're using.
myPort = new Serial(this, Serial.list()[0], 9600);
// don't generate a serialEvent() unless you get a newline character:
myPort.bufferUntil('\n');
// set inital background:
background(0);
void draw () {
// everything happens in the serialEvent()
void serialEvent (Serial myPort) {
// get the ASCII string:
String inString = myPort.readStringUntil('\n');
if (inString != null) {
// trim off any whitespace:
inString = trim(inString);
// convert to an int and map to the screen height:
float inByte = float(inString);
inByte = map(inByte, 0, 1023, 0, height);
// draw the line:
stroke(127,34,255);
line(xPos, height, xPos, height - inByte);
// at the edge of the screen, go back to the beginning:
if (xPos >= width) {
xPos = 0;
background(0);
else {
// increment the horizontal position:
xPos++;
