Trouble with GY-50 L3G4200 gyroscope and Arduino UNO
Hey Guys,
I just got a GY-50 L3G4200 gyroscope from Amazon: http://www.amazon.ca/gp/product/B008KWQ8LK/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
I connect the wires (Also tried connect CS--VCC) and use the code referring to: http://bildr.org/2011/06/l3g4200d-arduino/
//Arduino 1.0+ only
#include <Wire.h>
#define CTRL_REG1 0x20
#define CTRL_REG2 0x21
#define CTRL_REG3 0x22
#define CTRL_REG4 0x23
#define CTRL_REG5 0x24
int L3G4200D_Address = 105; //I2C address of the L3G4200D
int x;
int y;
int z;
void setup(){
  Wire.begin();
  Serial.println("starting up L3G4200D");
  setupL3G4200D(2000); // Configure L3G4200  - 250, 500 or 2000 deg/sec
  delay(1500); //wait for the sensor to be ready
void loop(){
   getGyroValues();  // This will update x, y, and z with new values
  Serial.print("X:");
  Serial.print(x);
  Serial.print(" Y:");
  Serial.print(y);
  Serial.print(" Z:");
  Serial.println(z);
  delay(100); //Just here to slow down the serial to make it more readable
void getGyroValues(){
  byte xMSB = readRegister(L3G4200D_Address, 0x29);
  byte xLSB = readRegister(L3G4200D_Address, 0x28);
  x = ((xMSB << 8) | xLSB);
  byte yMSB = readRegister(L3G4200D_Address, 0x2B);
  byte yLSB = readRegister(L3G4200D_Address, 0x2A);
  y = ((yMSB << 8) | yLSB);
  byte zMSB = readRegister(L3G4200D_Address, 0x2D);
  byte zLSB = readRegister(L3G4200D_Address, 0x2C);
  z = ((zMSB << 8) | zLSB);
int setupL3G4200D(int scale){
  //From  Jim Lindblom of Sparkfun's code
  // Enable x, y, z and turn off power down:
  writeRegister(L3G4200D_Address, CTRL_REG1, 0b00001111);
  // If you'd like to adjust/use the HPF, you can edit the line below to configure CTRL_REG2:
  writeRegister(L3G4200D_Address, CTRL_REG2, 0b00000000);
  // Configure CTRL_REG3 to generate data ready interrupt on INT2
  // No interrupts used on INT1, if you'd like to configure INT1
  // or INT2 otherwise, consult the datasheet:
  writeRegister(L3G4200D_Address, CTRL_REG3, 0b00001000);
  // CTRL_REG4 controls the full-scale range, among other things:
  if(scale == 250){
    writeRegister(L3G4200D_Address, CTRL_REG4, 0b00000000);
  }else if(scale == 500){
    writeRegister(L3G4200D_Address, CTRL_REG4, 0b00010000);
  }else{
    writeRegister(L3G4200D_Address, CTRL_REG4, 0b00110000);
  // CTRL_REG5 controls high-pass filtering of outputs, use it
  // if you'd like:
  writeRegister(L3G4200D_Address, CTRL_REG5, 0b00000000);
void writeRegister(int deviceAddress, byte address, byte val) {
    Wire.beginTransmission(deviceAddress); // start transmission to device
    Wire.write(address);       // send register address
    Wire.write(val);         // send value to write
    Wire.endTransmission();     // end transmission
int readRegister(int deviceAddress, byte address){
    int v;
    Wire.write(address); // register to read
    Wire.requestFrom(deviceAddress, 1); // read a byte
    while(!Wire.available()) {
        // waiting
    v = Wire.read();
    return v;
3.3v-->VCC
GND-->GND
A4-->SDA
A5-->SLK
However, the result ends with "starting up L3G4200D" and nothing else shows.
Anyone met the same problem?
Help~~~
Is it a 3.3V or 5V device ?
How have you connected the I2C ?
I suggest you go and learn how I2C works.
Hi KevinSolar
Try running the I2C Scanner and let us know what results you get.
http://playground.arduino.cc/Main/I2cScanner
Regards
Ray
