Trouble with if() loop
I have some trouble with the following if() loop (its only part of the whole thing):
int ldr1 = A0;  // right ldr
int ldr2 = A1;  // centre ldr
int ldr3 = A2;  // left ldr
float stepsize = 1.8;
float angLR = 0.0;
 int right = analogRead(ldr1);
  int centre = analogRead(ldr2);
  int left = analogRead(ldr3);
          if((right > centre) && (angLR >= -90.00 && angLR <= 90.00))
              stepperh->onestep(BACKWARD,DOUBLE);
              angLR += stepsize;
              Serial.print("Angle LR °");
              Serial.println(angLR);
          if((left > centre) && (angLR >= -90.00 && angLR <= 90.00))
              stepperh->onestep(FORWARD,DOUBLE);
              angLR -= stepsize;
Were right, left and centre are analog readings from LDR’s. Everything works fine when “angLR” is between -90 and 90. But once angLR is -90 it wont move towards positive direction (even though the right LDR has more light). It should go -90,-89.2,-87.4,… instead it does nothing. Same thing in the other direction when angLR = +90.
Any help is appreciated.
Note: all LDR’s are working correctly and are correctly assigned.
Since you didn’t post the entire sketch I can’t tell, but what have you done to ensure that the value of angLR doesn’t ever get less than -90 or greater than 90. If it does exceed those values, then your if’s will never be true.
if you don’t already do something like this consider this modification to your code
float angLR = 0.0;
              angLR += stepsize;
              angLR -= stepsize;
         //  The following two lines of code ensure that angLR is never outside an
         // acceptable range.
         if (angLR < -90) angLR = -90;
         if (angLR > 90) angLR = 90;
You code only does something , when angLR is between -90 and +90. When it is less than -90, it will do nothing, there is no code for that.
If you want it to do something other than nothing, you will need another if ( ) for that, or change your logic.
If you are expecting if to loop, you have more troubles ahead.
